10-19-2009, 12:06 PM #1Member
- Jun 2008
- ohio
black- 1998 Camaro SS
how do i get clutch hydraulic line back in??
i put the tranny back in the camaro and im pretty much done except for i cant get the clutch hydraulic line back in the tranny, i thought u just push it in and it will lock in and be fine but i cant get it to stay in. any ideas?
10-19-2009, 12:19 PM #2
Make sure the white plastic ring is pushed all the way to the end. Put the line on as far as you can and then let the ring release.
For Pic look at 13.
http://www.installuniversity.com/ins...r_cylinder.htm
Hope this helps.
10-19-2009, 01:25 PM #3Member
- Jun 2008
- ohio
thanks for the info.....i tried what you said and i still cant get that line in right. ive been under there messin with it for about an hour now. idk what else to do with it.
10-20-2009, 04:47 AM #4Member
- Jun 2008
- ohio
ok i really need some help here guys, this is the last thing i have left and im trying to get the car to get dynotuned this friday. ive been trying to get this line in for two days now. u said to put the plastic ring all the way to the end and push the line in. do u mean the front end of the fitting so that it goes in tranny first or slide it back all the way towards the line itself? ive tried both ways about 5000 times but just wondering. do i need to open the bleed up on the slave so the line will connect or something?
10-20-2009, 07:57 AM #5
10-20-2009, 08:20 AM #6Member
- Jun 2008
- ohio
so if i open the bleeder before i put the line on then do i have bleed the system after i finally do get it hooked up? i didnt think i had to bc noone has push the clutch or anything since i took the tranny out.
10-20-2009, 09:50 AM #7
10-20-2009, 07:41 PM #8Member
- Jun 2008
- ohio
finally got it in lol. as soon as i cracked the bleeder open the line went right on and then we bleeded the clutch. Drove it down the road and everything is workin fine
Thanks for all your help, its much appreciated
10-21-2009, 05:49 AM #9
I'm glad you were able to get it back on. Now you get to have some fun driving it.
need help with hydraulic line
By turyg ls1 in forum Manual TransmissionReplies: 4Last Post: 10-25-2010, 07:12 PM -
Hydraulic Clutch Line Remover Tool
By SuperSport346 in forum ToolsReplies: 6Last Post: 02-11-2010, 04:41 PM -
Wanted: Hydraulic master cylinder clutch line
By Chronic442 in forum Parts Wanted / TradeReplies: 0Last Post: 05-12-2008, 02:56 PM -
NTB: Hydraulic Clutch Line 98-02 TA
By rbrack in forum Parts Wanted / TradeReplies: 2Last Post: 12-11-2007, 06:28 PM -
Hydraulic clutch line restriction!!! Simple inexpensive fix. Question???
By Rob00Taws6 in forum Manual TransmissionReplies: 1Last Post: 08-01-2007, 05:06 AM
