Results 1 to 3 of 3
    Allen
    1999 Z-28 Ragtop
    Problem with tail light
    Hey guys. I've got a 99 Z28 and the tail light has gone out on one side. I want to replace the bulb but how do you get the assembly out. I found the wing screw behind the trunck liner and removed it. The assembly will start to come out on the big side but won't release on the narrow end toward the outside of the body. What am I missing?
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    there should be another wingnut or nut on that side as well. if not, then it's a matter of wiggling it out.
    Allen
    1999 Z-28 Ragtop
    Thanks. You were right. I had to move the spare tire out of the way to get to it.
  1. Tail Light, Head Light Lens Cleanup, Body Work Questions
    By MAXX2 in forum Appearance Section
    Last Post: 12-15-2010, 09:15 AM
  2. Question: Tail light
    By 01WS6 in forum Firebird / WS6
    Last Post: 10-14-2010, 01:41 PM
  3. Question: Tail light problem
    By izzhemp in forum Firebird / WS6
    Last Post: 08-26-2009, 07:09 PM
  4. light up middle tail light bird
    By trans_am7935 in forum Firebird / WS6
    Last Post: 05-28-2009, 08:59 AM
  5. tail light????
    By fhscoolguy27 in forum Appearance Section
    Last Post: 10-15-2007, 12:57 AM
