Results 1 to 20 of 20
Thread: Tail light
10-12-2010, 05:05 PM #1
- Oct 2010
- douglasville, ga
Pewter- 2001 trans am ws6 M6
Tail light
Im new on here so I dont know if this thread is in the right place but can anyone tell me whats wrong with my tail light the right one is way darker than the left one
Thanks!
10-12-2010, 05:20 PM #2
- Apr 2007
- bloomfield nj
Red- 1998 trans am
if the replaced the light they might have forgotten to put something back
10-12-2010, 05:21 PM #3
- Apr 2007
- bloomfield nj
Red- 1998 trans am
nice pewter metalic trans am welcome to the family
10-12-2010, 05:21 PM #4
the right one has water damage
10-12-2010, 05:23 PM #5
- Oct 2010
- douglasville, ga
Is there any way to get the water out or will it just happen again?
10-12-2010, 05:24 PM #6
- Apr 2007
- bloomfield nj
Red- 1998 trans am
how can you tell?
10-12-2010, 05:38 PM #7
- Apr 2008
- Madison, WI
It has water damage and needs to be replaced. Water gets into them and ruins the reflective chrome coating inside the taillight. Same thing happened to me. I bought a new one from GM.
If you go get a new one from the GM dealer, bring vaseline with you...so you butt won't hurt so bad as you walk out the door.
10-12-2010, 05:49 PM #8
- Oct 2010
- douglasville, ga
Thats not what i wanted to hear How much does a new light cost?
10-12-2010, 06:47 PM #9
Looks like you can get them from GM Parts Direct for about $230 new.
You could also try hitting some junk yards (might get lucky) for a used one that hasn't been water damaged. 98-02 Firebird tail light assembly, Firebird V6,Fornula or Trans Am should do.
I have the same problem as you on the same side... I'm keeping my eyes peeled for one but,looks like I'm going to have to pull the trigger on a new one.
Been also thinking of using VHT on the tails but,not sure if I like the look as much as stock.
Good luck!
10-12-2010, 07:05 PM #10
- Oct 2010
- douglasville, ga
Thanks guys looks like I'll be saving up for a new light
10-12-2010, 07:08 PM #11
- May 2009
- college station, tx
sold: 1999 firebird- 1998 Trans Am
i've bought and resold several used ones for about $70-$120, use craigslist.
PROTIP: drill some 1/8 inch holes (i did 5 on mine) on the bottom of the black plastic light housing, this creates a vacuum and a drain plug for trapped condensation, (you can see condensation in the clear backup lense) this is the tried and true way to prevent 100% of the chrome tarnishing and condensation.
I also drilled two tiny holes at the bottom corner of my DRL housings for the same reason, but thats another topic
10-13-2010, 05:36 AM #12
Same problem here.. except on the drivers side. I look daily to find a cheaper replacement casue there's no way I'll spend 400+ on a new pair from GM..
10-13-2010, 05:44 AM #13
- Oct 2009
- The Woodlands/spring/houston
pewter- 99 trans am
ive seen this on a lot of t/a's and it was always on the passenger side...i actually thought about asking this question a few days ago...guess my question is answered
10-13-2010, 05:52 AM #14
10-13-2010, 06:16 AM #15
- Apr 2008
- Madison, WI
You guys could also try to find a matching water damaged taillight for the other side for cheap on eBay. It would kinda look like you VHT'd both tails a bit darker
10-13-2010, 06:19 AM #16
10-13-2010, 06:35 AM #17
10-14-2010, 07:19 AM #18
Check out ebay or craigslist
10-14-2010, 10:46 AM #19
so has anyone figure out where the leaks are coming from?
Both of mine are starting to get a build up of water This past week end I had to take both off and drain them because I had an inch or two of water.
10-14-2010, 12:41 PM #20
Tail Light, Head Light Lens Cleanup, Body Work Questions
By MAXX2 in forum Appearance SectionReplies: 3Last Post: 12-15-2010, 08:15 AM -
Help: tail light
By somz28 in forum General HelpReplies: 2Last Post: 09-30-2010, 05:25 PM -
Tail light
By edrvsqz1980 in forum Firebird / WS6Replies: 7Last Post: 02-05-2010, 12:19 PM -
light up middle tail light bird
By trans_am7935 in forum Firebird / WS6Replies: 16Last Post: 05-28-2009, 07:59 AM -
Tail Light Out & More :(
By chaosinfinite in forum Camaro / SSReplies: 9Last Post: 10-15-2008, 09:23 AM
