Results 1 to 10 of 10
Thread: Check Engine Light
05-02-2007, 06:42 AM #1Member
- Oct 2006
- Houston, Texas
Red- 1998 camaro z28
Check Engine Light
If i take out my cats would my check engine light stay on? just askin.
05-02-2007, 07:11 AM #2
yes, if you remove the cats your SES light will stay on...
however if you were to get a tune, you can delete those error codes and the SES light would not come on...
05-02-2007, 08:14 PM #3Member
- Oct 2006
- Houston, Texas
My brother told me that, but i wasn't to sure to belive him. He's an "import" man.Thanks
05-03-2007, 03:16 AM #4
Or slap on some O2 sims and you will be good!
05-03-2007, 06:14 AM #5
05-08-2007, 04:43 PM #6
if i didnt put the 02 sims on could the tuner just turn them off?, what should i do , leacve stock sensors there or just remove? im in the same boat after header install
07-04-2007, 12:42 PM #7
I would just remove the sensors {in the rear} and get the codes tuned out. That would be the best way. Sims are junk, I'm working through that issue right now. You could try a non fouler witch will just pull the 02 sensor away from the exhaust flow but leaves them in place so you shouldn't get a {SES} light. If you go the non fouler route then you'll have to drill the tip of the fouler out to fit the o2 sensor in it.
07-06-2007, 06:13 AM #8
Your 02 sims plug into the rear harness on both sides then just zip tie them out of the way, They work too keep your light out, but if that doesnt bother you than you can wait until you get a tune. I used sims for about a year wit no issues and no check engine light, then i got the car tunned and the cats deleted.
07-07-2007, 08:16 PM #9Junior Member
- Jul 2007
- East Wareham, MA
Black- 2000 Trans Am
I cant stand the Check Engine Light on the Trans Ams. Ive had 7 of them over the last 12 years and the check engine light always comes on. In my opinion I would rather just disconnect the bulb to the light and use my ears to tell me when the car is having a real problem. Sometimes the gas cap can cause that the happen also. Otherwise im guessing there are many factors that can cause it to come on.
07-08-2007, 01:34 AM #10
leave the front 02s...sims in the back...problem solved
Check Engine light vs. Service Engine light
By bigrig73 in forum Computer & TuningReplies: 1Last Post: 04-20-2010, 06:11 AM -
Question: Check Engine Light
By 550hpbird in forum Computer & TuningReplies: 3Last Post: 02-13-2010, 04:07 PM -
Check Engine Light
By SailorZ28 in forum General HelpReplies: 15Last Post: 09-28-2007, 08:45 AM -
Service engine soon light = Check engine light?
By jinxeng in forum General HelpReplies: 5Last Post: 08-11-2006, 07:34 PM -
Check Engine Light has come on.
By Jim_s in forum Camaro / SSReplies: 6Last Post: 11-11-2005, 01:00 PM
