Results 1 to 20 of 31
Thread: O2 sensor question
04-29-2007, 07:33 PM #1
O2 sensor question
Are the rear o2 sensors necessary to run the car safely? I Just installed my headers (Pacesetters) and the o2 sensor on the driver side cannot be put in as it interferes with my shift linkage (auto). I plan on having a full tune as soon as I install the cam and rearend so do I need to worry about it? I don't care about SES code as since gutting the cats it has been on about 2 or 3 years now that the SES light has been on but I don't want or need any troubles if I just drive it for now until everything is put in place to where i need to go to install stuff.
04-29-2007, 08:32 PM #2
Just get some o2 simulators. I know summit sells them. I've had them in my car for a year with no problems.
04-29-2007, 09:12 PM #3
I had them they quit working like a year later. I think I wanna stick with something more permanent but I just need to make sure it can drive to the exhaust shop, and the tuning shop without any problems without a o2 sensor even plugged up.
04-30-2007, 11:16 AM #4Senior Member
- Jul 2005
- Jacksonville, FL
The rear 02's just monitor the status of the cats - front 02's are needed.
05-02-2007, 06:54 AM #5O U 8 1 2
- Nov 1999
- over here...
i have mine programed off due to my cats being gutted because they tooka shit on me...
05-02-2007, 07:17 AM #6I Love High-Explosives!
- Apr 2007
- Slatington, PA
Pewter- 2000 Trans Am WS.6
you're good. i just did my exhaust, caue i thought having no mufflers was making my o2 censors give me a reading...well i fixed the exhaust, and i still have the ses light pop on once in a while. no problems so far.
05-02-2007, 03:56 PM #7
so do you guys recommend that if i get long tubes ... get some new o2 sims? how can i tell if my 02 sims are out?
05-03-2007, 06:12 AM #8I Love High-Explosives!
- Apr 2007
- Slatington, PA
if your sims, or ever oem o2s are out, itll send a ses light. auto zone can run a free scan and tell you.
05-04-2007, 07:41 AM #9
i took my car to advanced auto parts and got bad news. both my 02 are out. it also dedected both cats throwing out some codes. i wanted to take my car to the dealership because I received a recall notice on the cats from gm, but i dont know if they will give me crap because of my cut-out and my lid.
05-04-2007, 01:35 PM #10I Love High-Explosives!
- Apr 2007
- Slatington, PA
just 2 o2s are out? there should be a total of 4 o2s on 2000 and newer. only 2 on 99 and older. cats are not cheap at all man. good luck.
05-04-2007, 02:08 PM #11Senior Member
- Jul 2005
- Jacksonville, FL
What were the codes, just P0420 and P0430?
05-04-2007, 02:28 PM #12I Love High-Explosives!
- Apr 2007
- Slatington, PA
if i remember right, those are the codes for the 2 rear o2s?
05-04-2007, 03:12 PM #13
i dont remember the codes. i have them at home, but if i remember correctly it said something about cats on there. ill post them when i get home. i do remember that there was 4 codes on there though. ill get back to u all tonight
05-04-2007, 05:28 PM #14
ok here we go, these are the codes that i got on my car:
P0171- system too lean (bank 1)
P0174- system too lean (bank 2)
P0420- catalyst efficiency below threshold (bank 1 )
P0430- catalyst efficiency below threshold (bank 2 )
05-04-2007, 06:58 PM #15
05-06-2007, 06:36 AM #16I Love High-Explosives!
- Apr 2007
- Slatington, PA
sorry bout the bum scoop. thanks for the correction wesman.
05-07-2007, 07:42 PM #17
05-08-2007, 12:51 AM #18I Love High-Explosives!
- Apr 2007
- Slatington, PA
damnit! all this talkin bout o2...now my f-in ses light came on for my o2's!
05-08-2007, 03:07 AM #19Senior Member
- Nov 2006
- Indianapolis
None of these codes are showing bad O2 sensors, they are exactly what they state. If you gutted your cats, that will be the 420 and 430 codes. Makes sense, eh? You need the O2 sims or tune out the codes in you PCM to take care of the efficiency problems, (I did, before I got my long tube Hookers, it was free at GM. I had a lid and not a stock muffler at the time, they said nothing about that stuff). If you have the system too lean codes, check your fuel pressure for a failing fuel pump (low pressure), you could have a MAF sensor out of spec (falsely showing not enough airflow) or it could be a leaky exhaust. Those are things to check for.
05-09-2007, 12:10 PM #20
i've had all 4 of my o2 sensors deleted. Im running just fine with out them
slp lid,maf and smooth bellow. ls6 intake, cnc ported and polished ls6 heads with competition valve job. cam 237,242 .603,.609 113 lsa. pacesetter longtube headers and off road y-pipe. magnaflow catback
dyno numbers on a mustang dyno
394 rwhp @ 6300 RPM
345.7 rwtq @ 4800 RPM
o2 sensor question
By Justin23454 in forum External EngineReplies: 8Last Post: 01-20-2012, 09:29 AM -
Cam Sensor Question
By henrysangret in forum External EngineReplies: 1Last Post: 01-17-2009, 11:42 PM -
02 Sensor question
By 97ss497 in forum General HelpReplies: 6Last Post: 03-26-2007, 08:36 AM -
o2 sensor question
By NE98LS1 in forum External EngineReplies: 5Last Post: 12-26-2006, 08:04 PM
