Thread: 02 Sensor question
03-23-2007, 08:40 PM #1
02 Sensor question
I'm installing headers on my girlfriends 99 Z28 and I screwed up the passenger side pre-cat 02 sensor when I was removing it. Will the downstream cat 02 sensors work? I'm also installing an off-road y-pipe so there will be no cats and I'll be using 02 sims.
Thanks in advance
03-23-2007, 08:55 PM #2We'll be back...
- THE SWAMP
Yes, you can use the rear O2 sensors since they are the exact same sensors. With headers, you'll need O2 sensor wire extensions since the pre-cat sensors are located further downstream on headers than on the stock exhaust manifolds.
03-23-2007, 09:00 PM #3
Thanks; that will save me some serious coin....
03-25-2007, 04:24 PM #4
Can I use passenger side 02's on the drivers side? I noticed there diff part numbers on the Thunder Racing websight. Maybe just a wire length difference?
03-25-2007, 06:18 PM #5
Yea it's just the wire length
03-26-2007, 06:51 AM #6
yepp been there done that, they are the same, both sides, pre cat and aft cat, the only difference is the wire length.
03-26-2007, 08:36 AM #7
Sweet! Thanks guys...
o2 sensor question
By Justin23454 in forum External EngineReplies: 8Last Post: 01-20-2012, 09:29 AM -
Cam Sensor Question
By henrysangret in forum External EngineReplies: 1Last Post: 01-17-2009, 11:42 PM -
O2 sensor question
By slims00ls1z28 in forum External EngineReplies: 30Last Post: 05-16-2007, 04:23 AM -
o2 sensor question
By NE98LS1 in forum External EngineReplies: 5Last Post: 12-26-2006, 08:04 PM
