Results 1 to 17 of 17
    Charlotte, NC
    Hugger Orange/W stripes
    1999 Z28 M6
    Differences in heater core replacement
    Recently while trying to change the infamous #8 plug, I managed to break loose one of my heater hoses (turns out the clamp slid off long ago). Anyway, I figured I had damaged the heater core and would have to replace it. Turns out I didn't, but the loose clamp was the reason I could always get a very slight coolant smell through my heater, but never used coolant, leaked, or got the smoked-up windows.
    My car is a '99. I have the GM manual set/Chilton's and I proceeded to educate myself on the heater core replacement, being I heard it was very involved. Good news!!! If you have anything from 1998 to (and including) the 2001 models, the replacement is fairly easy and only requires the removal of the glove box, other than the standard bolts/hoses associated with heater cores. Now the bad news, if you have a 2002 model; the procedure is much more involved and requires a lot of the dash area and components to be removed.
    Just wanted to put that tidbit out.
    San Diego
    2001 WS6 Pontiac TransAm
    I hope youre right Jad! Im getting the smoked up windows and coolant smell in my 2001 WS6, so all I gotta do is remove the glove box and get to the heater? Anyone out there done a heater core in a 98 to 2001? Any advice would be appreciated. Im settting a time frame of 4hrs to complete, is this reasonable? Thanks.
    Charlotte, NC
    1999 Z28 M6
    Quote Originally Posted by Toneloc71sr View Post
    Good luck. I think you are in good shape with a 2001 model.
    Let us know how it pans out.
    San Diego
    Thanks, hopefully I wont need it I did a search and found one guy here saying he needed special clamp tools to get to the clamps. Were you able to get to the clamps easy enough with regular pliers or do I need to go out and get clamp tools?
    Senior Member GULLETT17's Avatar
    Muncie, IN
    00 TA PWTR, 98 VertTA NBM
    80 TA BLK, 80 Formula NBM
    hmm. . i wonder why they would have changed for 2002?
    Charlotte, NC
    1999 Z28 M6
    Get a clamp tool. It may not be absolutely required, but it will be worth the expense (less than $10) in making the job easier.
    Reach back to the firewall with regular pliers and see how good you are at manipulating those clamps. My big mitts didn't fare very well.
    doylestown, Pa
    SILVER
    2004 CTS-V
    I did a heater core on my 97 and it is the same as the 98. It was actually very easy. The hardest part was getting the anti-freeze smell out of the car. It soaked the front and the back, and I had to steam clean the whole carpet!!
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    I hate antifreeze, the stuff is garbage. You'd think, out of all the liquids in the world, that they could come up with a coolant that doesn't smell bad, isn't corrosive, and isn't toxic and environmentally damaging.
    All it really has to do is not freeze or corrode metal, and have the ability to absord and carry heat away (like water). I don't see whats so difficult about that, but apparently it has the world's greatest chemists stumped
    San Diego
    So I did it last night. Wow, the inside of the car was very very easy, I was impressed how easy it was, only took me like 10mins to get down to the core. I was able to remove the clamps from the engine compartment side but must say that was the biggest hang up!!!! Took me like 1hr 20mins to remove two small clamps!! Theres a tool at sears that removes clamps easily:
    http://www.sears.com/shc/s/p_10153_1...pecialty+Tools
    But when I went to my local Sears, they were out! Would have saved me 1hr at least.
    TEXAS... U mad?
    Black / Stryker Blue
    2K WS.6/ 2K9 G8GT
    Quote Originally Posted by GULLETT17 View Post
    misinformed?... 2002 was the same as 2001... no difference.
    firebirds from 1993 on are quite easy
    TEXAS... U mad?
    2K WS.6/ 2K9 G8GT
    you got this outta chilton's???
    Charlotte, NC
    1999 Z28 M6
    Either that, Haynes, or the GM manuals (set of 3). It didn't really matter to me since I have a '99, and the one time I inquired about having it done from a mechanic who had an '02 SS, he said it was a pain in the ass from the dash side.
    I just looked in Haynes and it says:
    Note: On 2002 models the entire instrument panel and cowl bracing must be removed to access the HVAC module, which must be removed from the car to access the heater core." Chapter 3, Page 9, Section 11.
    All theoretical study from my standpoint for now.
    doylestown, Pa
    SILVER
    2004 CTS-V
    ^That can't be true!^
    Charlotte, NC
    1999 Z28 M6
    I didn't print the thing!!! That's what it says though.
    I don't have a 2002 so I can't say for sure.
    TEXAS... U mad?
    2K WS.6/ 2K9 G8GT
    we arent callin you a liar. just wanna do some research as to why gm would have changed the last year when they knew it was doomed some time ahead.
    doylestown, Pa
    SILVER
    2004 CTS-V
    we arent callin you a liar. just wanna do some research as to why gm would have changed the last year when they new it was doomed some time ahead.
    X2.....
    Charlotte, NC
    1999 Z28 M6
    If ya'll find out, please let everybody know. I didn't understand it either, but there it was in B&W.
  1. Question: heater core delete
    By 98TransAmWs-6 in forum General Help
    Last Post: 01-01-2013, 08:12 PM
  2. Help: Heater Core Replacement (2000 Camaro LS1)
    By TerribleTed in forum General Help
    Last Post: 03-02-2011, 02:50 AM
  3. Heater core bypass
    By hix5000 in forum General Help
    Last Post: 07-14-2008, 03:42 PM
  4. Frozen Heater Core
    By my5thNewUsernameHere in forum LT1
    Last Post: 06-01-2007, 05:12 PM
  5. '99 Heater core replacement
    By jad628 in forum General Help
    Last Post: 11-08-2006, 04:54 PM
