Results 1 to 17 of 17
    Apr 2010
    Alabama
    Black/ Silver
    98 TA WS6/ 01 C5 Corvette
    heater core delete
    I have a question on deleting the heater core and the box attached to the firewall. I have removed everything up to the box on the firewall and behind it. When deleting your entire hvac system, does everything under and behind the glove box go? I just don't want to accidentally remove a module for the airbags or some other thing besides an hvac component.
    1998 Trans Am WS6 - Phantom
    421 LQ9 14.8:1 on E85 Build/
    the airbag sensor component is located under the center counsel just behind the e-brake, under the armrest pocket you use for spare change and stuff. The bcm is located just behind the glove box and IIRC is mounted to the heater core box wall.
    Arizona
    You've gutted that thing and you still have air bags?
    Apr 2010
    Alabama
    Black/ Silver
    That may change but not atm. What does the bcm look like, so I don't remove it. I am guessing it needs to stay right? I guess my main question is can everything behind the glove box go?
    Arizona
    There was a picture of it here somewhere, I'll see if I can find it.
    Can't mistake it though. You'll need it if you want things like radio, windows and locks, alarm, remote time delay etc...to work, if those aren't gutted yet.
    Apr 2010
    Alabama
    Black/ Silver
    Okay so I will keep it then. There is a module that is cylindrical and silver. Would that be it? It looks like I would need to take it off to remove the heater core box and then reattach it to the hvac delete plate.
    Apr 2010
    Alabama
    Black/ Silver
    If this is the bcm, this is in my engine compartment right next to the drop down to access my drivers daytime running light and turn signal.
    Arizona
    Wow, must be different on the 98's then?
    Apr 2010
    Alabama
    Black/ Silver
    I will take a picture of what is behind the glove box.
    Apr 2010
    Alabama
    Black/ Silver
    Nvm the bcm on the right. There is another box that looks like it in my engine compartment. What is that silver cylinder?
    Orlando, FL
    Mean Black
    Quote Originally Posted by 98TransAmWs-6 View Post
    if you are refering to the cylinder with the orange vaccum line connected to it, it looks like a vaccum tank.
    Apr 2010
    Alabama
    Black/ Silver
    Okay thanks I already removed it. For some reason I do not see anymore bolts or screws but the whole box won't come loose
    Apr 2010
    Alabama
    Black/ Silver
    I removed everything but the box! So far so good.
    Apr 2010
    Alabama
    Black/ Silver
    What is this? I am trying to figure out how to remove it since it is in the way of the box on the wire wall for the heater core.
    Jun 2011
    Branchville, NJ
    Silver & Blue
    02 Camaro SS, 04 GTO
    That is your fan speed resistor. It can go if you do not plan on using you fan anymore.
    Apr 2010
    Alabama
    Black/ Silver
    Quote Originally Posted by 2002ssslp View Post
    Alright out it goes. At some point I will pull the dash to get the rest of the duct work and airbags.
    Apr 2010
    Alabama
    Black/ Silver
    And I am rid of that box, I just need to get the delete plate in!
  1. heater core hoses
    By v6camaro in forum V6
    Last Post: 02-26-2011, 08:54 PM
  2. Heater Core Problem?
    By BirdCountry02 in forum General Help
    Last Post: 12-30-2010, 05:55 PM
  3. Heater core bypass
    By hix5000 in forum General Help
    Last Post: 07-14-2008, 04:42 PM
  4. Frozen Heater Core
    By my5thNewUsernameHere in forum LT1
    Last Post: 06-01-2007, 06:12 PM
  5. '99 Heater core replacement
    By jad628 in forum General Help
    Last Post: 11-08-2006, 05:54 PM
