Results 1 to 20 of 23
04-24-2007, 06:40 PM #1
Anyone got a write-up on replacing a fuel filter?
At 110k...it might be time to change the filter.
It was pretty easy on the 94 mustang gt I had, but what about these? How do you go about it?99 T/A M6
LS6 intake, Hooker Coated Long Tubes, Y-pipe w/1 carsound cat, Hooker Catback, MTi Clear Lid, FRA w/ Holley Power Shot, ASP crank pulley, 1.8 RRs, 3.73s w/TA girdle & Eaton Differential, Granatelli SFCs, Pro 5.0 Shifter, LS6 Clutch, Diablo, TByrnes Maf Ends (in winter), All the Free Mods
04-24-2007, 07:21 PM #2
04-24-2007, 07:23 PM #3
He beat me to it.
Yeah its pretty straight forward. Just undo the end with the nut then undo the quick disconect pull it out then put the new one in. Also undo your gas cap before you start to relieve any pressure in the system, you'll still end up with gas on you but it should't be as bad.
Wow 30-60 min expected time that total bs more like 10-15 min tops.
04-24-2007, 07:37 PM #4ArtistFormerlyKnownAsMac
- Apr 2006
- Indianapolis, IN
All Black- 83, 87, 02 All WS6 T/As
-Geno
1983 Black WS6 "WindCharger"
1987 Black WS6 "WS87"
Sold the other four f-bodies
04-24-2007, 08:36 PM #5Awaiting Activation
- Mar 2006
- LS1 land
at 110k you are definately due. I replaced mine around 70k and when i did i cut open the old one. The insides looked like complete shit. I wished i had done it sooner.
04-25-2007, 03:49 AM #6
GM recomends replacing them every 30k
04-25-2007, 07:48 AM #7
Well I doubt Id notice a performance increase, but what about mileage?
And how much does a fuel filter run?
04-25-2007, 11:24 AM #8Junior Member
- central coast
04-25-2007, 06:36 PM #9
funny cuz i do the same thing. just for peace of mind.
also you could see a performance increase if yours it stopped up, maybe not much but something. a tip--after you take it off, blow thru it with your mouth the way the fuel goes thru. you can tell how stopped up it is by comparing it with your new filter.
04-25-2007, 06:48 PM #10
Any particuliar brand I should be shopping for? how much?
04-25-2007, 07:31 PM #11Junior Member
- central coast
I just used whatever they had at my local Autozone, think it mught be Fram. Anyhow they shouldnt be more than 10 bucks. And yes, you will feel a difference.
04-25-2007, 07:48 PM #12
glad i seen this thread i need to change mine
04-26-2007, 03:59 AM #13
get a delco
04-26-2007, 02:39 PM #14
05-02-2007, 07:03 AM #15
First time replacement...
Well, I did my filter change yesterday for the first time on this car. Id say it was about as hard as changing oil.
And yes, it took just under an hour..including driving to the store and back, plus finding the right tools in the garage. Why the fuck must I have all English measurement tools?
The ONLY bitch was the fuel line. I was surprised it was rubber, in any case, making room for it to com eout of the filter was annoying. I bent the rubber hose.
After I reinstalled the new filter, i took a gander at the fuel line to make sure no permanent damage occurred. So far so good. No leaks.
I blew through both filters and there really wasnt that much of a difference. Well, there was at first.... I blew through it and it was terrible, then dirty gas came out. Then it was almost as free flowing as the new filter.
No performance increase.
05-02-2007, 03:35 PM #16
got my ac delco filter today at advance $17
05-02-2007, 03:55 PM #17Junior Member
- Feb 2006
- GARDEN GROVE, CA
BLACK- 2002, CAMARO Z28
I too bend the fuel line when changing mine. One tip I read afterwards is to undo the fuel line strap that is located back as bit from te filter which gives more flex to get the line off.
05-02-2007, 04:05 PM #18Member
- Jul 2006
- Vancouver,B.C.,Canada.W.Coast
Navy Blue Metallic- '99 T/A WS6 M6
....Get under the car with some wrenches..one end has a nut--the opther end is a small clamp.....and remove it--then replace with new filter..EASY......[it is located under the rear most area of dr. door by frame rail.....[very easy...loossen the gas cap first---DO NOT bother with fuel rail in engine bay as some may suggest...HONESTLY..get a rag and there should only be a bit of gas in the ends of lines and whatever is in the filter...] you will not be afraid ..it is a simple method..good luck...really--no problem at all...
99 WS6 M6 NBM !Cags,!Cats,Vinci/Crane,Hurst,Detroit TruTrac,3:73,31 Splne,Edel.Race LT's,ORY,QTEC,Flow,ARP,Percy,MSD,SLP,AC/DELCO,Bosch,GMPP,Cntrfrce DF,Htchkiss,Susp.Tech,Lakewood,285's,Bilstein,Pro-kit,SLP,RK Sprt,A/Meter,Red Optima,Magnaflow S/S Tips,Hd Pins,Tint,Fire.Ex,[*4 Hot Rod Power Tours*]
05-03-2007, 07:43 AM #19
05-03-2007, 07:44 AM #20ArtistFormerlyKnownAsMac
- Apr 2006
- Indianapolis, IN
I was kinda thinking the same thing.. but
kinked fuel line while changing fuel filter
By krese in forum Firebird / WS6Replies: 4Last Post: 10-04-2010, 03:02 PM -
Where is the fuel pump write up ?
By Danger731 in forum General HelpReplies: 11Last Post: 11-11-2009, 10:11 AM -
replacing fuel filter en brake fluid ?
By pv-camaro in forum General HelpReplies: 5Last Post: 08-15-2009, 04:39 AM -
Question: replacing O2 sensors write up?
By DrMilhouse in forum General HelpReplies: 1Last Post: 05-19-2009, 02:22 PM
The fuel will be filtered by the media inside so air passing thru is not very scientific and I would avoid fuel in mouth contact.
