11-09-2009, 10:09 AM #1
Where is the fuel pump write up ?
I want to put in another fuel pump - walbro / racetronics in my Z/28 isn't there a write up ?
04 C5 A4 Torch Red - sold
2009 CTS4 Ice Black - sold
2013 1500 Silverado Z71 - sold
02 Z/28 M6 Onyx Black All Options - Sold
2014 Caddy CTS4 - DD
2016 Silverado 2500HD
2020 Caddy XT6
2020 2SS Vert
11-09-2009, 10:23 AM #2Senior Member
- Aug 2001
- San Diego, CA
383 w/Meth & ProCharger- 2001 Camaro Z28
Do you plan on dropping the rearend and tank or cutting through the rear deck? I'll have to look for a link once you decide which plan of attack you go with.
11-09-2009, 11:46 AM #3Awaiting Activation
- Oct 2007
- NC
SOM- 1998 T.A.
The trap door is SOOOOO much easier. Just rivet a piece of tin over the TD and nobody will ever know it's there.....
11-09-2009, 11:47 AM #4
I agree about the trap door mod. It's so much easier than dropping the tank
11-09-2009, 01:54 PM #5
11-09-2009, 02:21 PM #6
3 hours tops (no cutting).
1. Raise and support the rear of the body on jack stands, leaving only the jack under the axle.
2. Remove the lower shock bolts.
3. Remove panhard bar and lateral support.
4. lower axle only but still supported by jack.
5. With axle lowered remove driver wheel well cover there's no need to remove the wheel.
6. Remove filler neck bolt one 10mm.
7. Support tank.
8. remove the tank saddle bolts swing out of way.
9. lower tank SLIGHTLY.
10. reach in and disconect the wire harness and quick disconnects @ the top of pump housing and one on the body near the harness plug.
11. Lower tank and tilt down and towards rear bumper, it will slide out and off your support.
12. Remove old pump, then reverse assemble..Last edited by Smittro; 11-09-2009 at 02:24 PM.
11-09-2009, 03:27 PM #7
wow maybe this could be done on a lift with a tranny jack ?
11-09-2009, 03:35 PM #8
11-09-2009, 04:49 PM #9
11-09-2009, 09:28 PM #10
11-10-2009, 09:14 AM #11Awaiting Activation
- Oct 2007
- NC
SOM- 1998 T.A.
11-11-2009, 10:11 AM #12Junior Member
- Oct 2009
- Macon Ga
Black- 02 Z28 Turbo
We just did a dual intank setup on our 02 ss.
{actually used Ford SVT Focus Fuel Pumps as we use them in a ton of the fords we build}
We used the trap door method.
Were holding 80psi @ idle with 42lb injectors and it only falls off to 60lbs @ 15psi of boost.
I say this merely as Im sure we will be in there as needed, so the trap door seems like the logical choice..
Write-Up: Fuel Pump Kill Switch
By nichoLaS1 in forum General HelpReplies: 19Last Post: 03-13-2016, 09:30 AM -
LS1 all yr fuel injectors, oe fuel rail, pump,more
By Frost in forum Parts For Sale / TradeReplies: 7Last Post: 04-27-2009, 02:26 PM -
Anyone got a write-up on replacing a fuel filter?
By AKIRA in forum General HelpReplies: 22Last Post: 05-07-2007, 07:32 AM -
Stock fuel pump/ how much fuel pressure can I run...
By jmangler in forum LT1Replies: 3Last Post: 10-02-2006, 06:23 PM
