Results 1 to 20 of 21
Thread: LS6 intake damaged
04-24-2007, 03:14 PM #1Junior Member
- Jan 2006
- Granada Hills,CA
Black- 1999 Camaro SS
LS6 intake damaged
I just purchased a LS6 intake for my 2000 Camaro SS unfortunately it was damaged during shipping right near the valve in the back of it. Does anyone know how to repair the composite if possible?
04-24-2007, 03:22 PM #2Senior Member
- Jul 2005
- Jacksonville, FL
Welcome to the board. Did you get it new or from a private seller? Was it insured, can you send it back?
04-24-2007, 03:59 PM #3Member
- Mar 2007
- Massachusetts
Black on Black on Black- 2002 Camaro SS Vert
I would also add if you received it from UPS, FedEx or DHL make sure you file a claim with them soon. You just call their 800 numbers to start the process. Sometimes they want the shipper to start the claim but best to call just to have it on record. Take pics if you can and save the packaging if you still have it. This can help get the claim processed. Regardless of who you bought it from if it was damaged in shipping you should be ok. The only chance would be if the shipper didn't pack it correctly. Then the blame falls on them....Good luck
04-24-2007, 06:45 PM #4
Also I would ask what method of payment that you used. If the shipper and/or the carrier are not willing to help, then you can always have a charge back filed through your credit card company. Even if it was a debit card, most are still backed by visa, mastercard, amex, or discover. In either situation a damaged product that the seller is unwilling to exchange or accept as return, is grounds for a chargeback. A similar process can take place through paypal if you paid using their service. I have went through this process both with Paypal and credit card provider in the past. Good luck!
04-24-2007, 11:41 PM #5Junior Member
- Jan 2006
- Granada Hills,CA
Thanks, I actually got in contact with the seller and he told me that it was insured through Fed Ex, I did purchase it through Pay pal and put in a claim with them. Luckily I was able to fix the intake manifold tonight with some fiber glass resin. It got damaged right near the MAP sensor in the back of the manifold. The only thing is I don't know for sure if this resin will hold up, is it worth keeping? Hopefully tomorrow when I put in the claim with Fed Ex they can possibly reimburse me for the damage since Im willing to keep the manifold. Thanks for your help. Let me know if you have any other suggestions.
04-26-2007, 01:52 PM #6
Of course it is worth keeping! Heat up the resin a little so it seeps into the crack!
04-26-2007, 01:53 PM #7
thats kinda ifffy but heyt if it works
04-26-2007, 01:55 PM #8
04-27-2007, 12:49 AM #9Junior Member
- Jan 2006
- Granada Hills,CA
Thanks, So far so good with the repair I sanded down the resin on the back of it, and it looks great! But I've been getting negative feedback from friends if the resin will actually hold up so we'll see. Im still contemplating on keeping it or selling it, if I do I'll most definately let you guys know. Mainly all thats going through the intake is air being vacuum in and not necessarily pressurize, I deffinately think this resin should hold up.
04-27-2007, 02:22 PM #10
04-27-2007, 02:31 PM #11
04-28-2007, 08:29 AM #12Junior Member
- Jan 2006
- Granada Hills,CA
Any suggestions on how I would test the manifold to see if its leaking or not from the back? water and air?
04-28-2007, 08:50 PM #13Senior Member
- Jul 2005
- Earth
414 RWHP 395 RWTQ- 00 Black Ram Air Trans Am
I bought one which was damaged in shipping, glued it up at a performance shop and it held...........for 2 weeks. Than it cracked again where the brake booster line was and my brakes failed leaving my work parking lot....not fun. Ended up selling it because I was fed up and the new guy bought a map sensor for it from GM, cost around $65-$80 I believe for a new one. Good luck and be careful
04-29-2007, 03:17 AM #14Pontiac Addict
- Mar 2007
- Northern Indiana
Black on black- 2003 Bonneville SSEi S/C
Dude get rid of that! If it got damaged, they should send you a new one. You shouldn't ever settle for damaged products, even the minute problems could turn into big ones like Hurley mentioned. Get them to send you a new one and sell that broken one to 9t8z28
04-29-2007, 03:27 AM #15
04-29-2007, 03:30 AM #16Pontiac Addict
- Mar 2007
- Northern Indiana
Exactly. On something like a 4 door sedan that makes 130hp, then that would be a great fix on a budget, but not something that makes 320hp. Especially something that you probably spent a lot of money on, and means a little more to you than installing broken components...
04-29-2007, 05:44 AM #17Senior Member
- Jul 2005
- Earth
The only thing I can recommend is to see how much a new map sensor costs, other than that send it back and get your $$$$
04-29-2007, 05:13 PM #18Junior Member
- Jan 2006
- Granada Hills,CA
Thanks guys, overall the MAP sensor is fine it was just the actual manifold that was damaged right near the MAP sensor opening. Im hoping Fed Ex will reimburse me for the damages and inconvenience, its been a hastle and if the resin isnt going to hold up on the manifold I definately don't want to keep a broken manifold.
04-29-2007, 05:36 PM #19Pontiac Addict
- Mar 2007
- Northern Indiana
Oh the manifold itself cracked? No way dude, get that shit refunded. Its gunna keep cracking.
04-30-2007, 02:19 PM #20Junior Member
- Jan 2006
- Granada Hills,CA
That Fiber glass resin is suppose to hold up against heat under the hood, So I dont know if its still worth keeping with the repair done to it.
Used/damaged ls1 cam
By reedld in forum Parts Wanted / TradeReplies: 1Last Post: 01-17-2017, 03:11 PM -
Question: Alternator Damaged??
By flybird in forum V6Replies: 9Last Post: 12-29-2011, 06:32 AM -
Question: ported TB damaged
By 98maro in forum General HelpReplies: 37Last Post: 12-23-2010, 08:50 PM -
NEED a GTO hood any thats not damaged.
By q1234567890 in forum Parts Wanted / TradeReplies: 0Last Post: 03-24-2006, 06:15 AM -
WTB: Bare LS1 block/heads/intake, T-56 (damaged) for mockup (No. Cal)
By Dan [Sac] in forum Western MembersReplies: 7Last Post: 03-21-2006, 01:30 AM
