Results 1 to 20 of 38
Thread: ported TB damaged
11-25-2010, 07:21 PM #1Senior Member
- Feb 2010
- north bay california
Black- 00 camaro ss M6 #6695
ported TB damaged
hey guys i have a question.. i bought this stock tb from ebay,,
but whe i opened the box,, i notice some broken pieces inside the box..
i contacted the seller but i have the feeling the guy dnt belive i got it like that..
anyways my question is.. is it safe to install it like that??
u guys think it can get damaged even more if it already installed??
thanks
02 tahoe Z71 blacked out
98 z28 red m6 sold
07 zx6r ninja flat/black sold
08 zx6r ninja sold
11-25-2010, 07:26 PM #211 years of bangin gears
- Jan 2009
- North Jersey
I dunno. Never seen a damaged throttlebody. You could try some JBWeld and fill that chip and file it down. Or have someone weld that chip shut. Your call.
Also, was there any packing material in the box(bubble wrap, newspaper)? If not, then the seller is responsible as he/she should have wrapped that TB in some sort of protective covering.
11-25-2010, 07:41 PM #3Senior Member
- Feb 2010
i dnt think i can weld it bk together cuz the little piece missing on the tb is broken in two pieces,,
idk why that happened, it was wrapped fine.. and thats what the seller said.. it was wrapped correctly, the box is not damaged or anything.. and i dnt think the seller is taking responsability for that..
the TB is very thin on the front of it.. i guess thtas why it happn
11-25-2010, 07:49 PM #411 years of bangin gears
- Jan 2009
- North Jersey
Sounds like the seller dropped the TB and is acting clueless. If you can find a shop that can heliarc weld, try them. But you could try the JBWeld and once it hardens, use a Dremel with a grinding stone attatchment.
11-25-2010, 07:53 PM #5Senior Member
- Feb 2010
i contacted the guy. and idk yet if hes gonna replace it..but i fnt have time to wait another week..
probably he dropped it.. i thought bout that to,,
im a try to put it bk together... you think i could mess up anything if i dnt repair it??
like it can get messed up with the heat or somethin, cuz i dnt want one of those pieces in my intake...
thanks for the help..
11-25-2010, 07:56 PM #611 years of bangin gears
- Jan 2009
- North Jersey
Could cause some turbulence in the airflow. I dunno for certain. If you're worried about heat then try the JBWeld/die grinder fix.
11-25-2010, 08:08 PM #7Senior Member
- Feb 2010
true.. i forgot bout the air flow and stuff..
im a try that n see how it works..
thank u so much for the help..
11-25-2010, 08:14 PM #811 years of bangin gears
- Jan 2009
- North Jersey
Not a problem.
11-25-2010, 10:03 PM #9
you said the walls are thin?....i wouldnt use that tb then b/c lets say something else breaks off of it and gets into your engine and fucks somethin up...i wouldnt chance it
just my .02
11-25-2010, 10:08 PM #10Senior Member
- Feb 2010
yes,, the end of the mouth is very thin on some parts,,
thats one thing im afraid of..
im a try to fix it.. but im sure the seller has to do something bout it..
cuz i paid for something that should work fine, cuz i paid for that,
11-25-2010, 10:10 PM #11
11-25-2010, 10:15 PM #12Senior Member
- Feb 2010
i could do that.. but idk.... if he doesnt take care of this..im gonna have to open a case..
i bought one b4 from him...no problms at all..
11-25-2010, 10:26 PM #13Slow'er'Ass
- Thornton, CO
Hopefully it is something that happened in transit.
Either way, it sucks.
Does it feel solid around the spot that broke??
Do you have one on the car so it can be driven?
11-25-2010, 10:47 PM #14Senior Member
- Feb 2010
It feels solid around the damaged.
But like I said it feels very thin.
It doesn't feel like it's gonna it's gonna brake more. But I want to be safe.
The car has it's own tb. I had an extra one n I sent it to him. N I got this one.
11-25-2010, 10:52 PM #15Slow'er'Ass
- Thornton, CO
That is good. At least it can be driven while you deal with it.
Good luck. Let us know what the seller ends up doing....
11-25-2010, 11:16 PM #16Senior Member
- Feb 2010
Thank you.
I will. And thanks to all of u for the help and replies.
I let u guys knw what's gonna happen. Thank you
11-26-2010, 03:10 AM #17
outer edge of the TB was ported too much.. What you have there is someone not knowing what they're doing porting things..
I would deffinetly get my money back. If not file a dispute.. TB's are made from cast aluminum.. Anyone (not dirrected @ you) with experiance with things make from cast aluminum should know its brittle. If it were a billet unit you could get away with a thin lip on a ported TB.. The leading edge should have been "rolled" instead... Now the outer edge is too thin to support the tightness of a clamp..imho
As stated I would'nt chance it..Last edited by Smittro; 11-26-2010 at 03:15 AM.
11-26-2010, 03:38 AM #18Member
- Apr 2009
- Pennsylvania
Pewter- 2000 Camaro SS
I was porting a spare throttle body i had and accidently went to far about a quarter the way in, in a very thin spot. I took JB weld and filled the whole and ground it smooth. It seems to be fine.
11-26-2010, 06:23 AM #19Senior Member
- Apr 2008
- Madison, WI
That little chip on the edge there is not a big deal. The clamp goes well inside of that. I'd run that TB without worries
11-26-2010, 12:08 PM #20
Used/damaged ls1 cam
By reedld in forum Parts Wanted / TradeReplies: 1Last Post: 01-17-2017, 03:11 PM -
Question: Damaged Lips
By pajeff02 in forum Wheels and TiresReplies: 3Last Post: 02-24-2009, 04:13 PM -
New .600 Springs, Ti Retainers, LCA Relo. Brackets.Ported MAF, Ported 99 TB & More
By [email protected] in forum Parts For Sale / TradeReplies: 5Last Post: 11-02-2007, 09:22 PM -
LS6 intake damaged
By Timemarcheson502 in forum External EngineReplies: 20Last Post: 04-30-2007, 06:20 PM -
SLP LS6 intake, Whisper Lid, Ported Throttle body, Ported MAF
By cru ss n in forum Parts For Sale / TradeReplies: 15Last Post: 05-24-2006, 08:22 AM
