Thread: Gauge install
04-21-2007, 01:30 PM #1
Gauge install
Anybody have good advise on installing auto meter gauges (water temp,oil pressure, vac) I had them on my old 3rd gen camaro and want to install them on my 99 t/a with the tri pod pillar. Info on oil tube placement, water sensor placement and any holes in the firewall that can be used as aposed to drilling more. Also monster tach install, I was told to tap into the #10 or eleven wire on my cpu and it would send the signal for the tach if it was in 4 cylinder mode. It ended up always draining my batt. anyone ever use that module that autometer sells to adapt the tach to a electronic signal.
thankx
04-21-2007, 01:32 PM #2Slow'er'Ass
- Thornton, CO
Type of gauges?
Are they electrical or mechanical?
I know you can't use a mechanical water temp sender.
04-21-2007, 02:26 PM #3
the gauges are all mechanical
04-21-2007, 02:31 PM #4Slow'er'Ass
- Thornton, CO
Water temp won't work. That HAS to be electrical sender to fit the LS1.
Unless there is another company that makes a small mechanical sender....
04-21-2007, 07:30 PM #5
You want to use electric guages for the track. Mechanical won't pass tech.
I think, they don't want fluids ( oil, fuel, ect ) in the cab of car. NHRA
Ultra gauge install
By 10spokess in forum Camaro / SSReplies: 4Last Post: 01-15-2013, 06:51 AM -
Need help with gauge install!
By camarostripes96 in forum Appearance SectionReplies: 7Last Post: 07-27-2009, 04:13 PM -
Air/ Fuel Gauge Install
By 99WS6MAN in forum General HelpReplies: 2Last Post: 03-13-2007, 07:41 AM -
gauge install
By TROYWS6X in forum General HelpReplies: 10Last Post: 05-18-2006, 03:08 PM -
Gauge and pod install....
By Mr. Luos in forum General HelpReplies: 6Last Post: 08-25-2005, 05:43 PM
