    Import Killer camarostripes96's Avatar
    Aug 2006
    academy,tx
    1996 Trans am
    Need help with gauge install!
    ok well was given a brand new dual gauge pod, i am wanting a fuel/air and a water temp gauges in there!! first i have never done any gauge hookup and just need to know where do i hook the air/fuel ratio up at and where do i hook the water temp up at? also what gauges do yall prefer?
    please let me know asap i wanna do this soon!! thanks
    TJEA Retirement Home Dr.Crash's Avatar
    Feb 2006
    U. S And A Greatest country in all of world
    Stock
    2002 Camaro
    i went with wide band 02 and fuel pressure. wiring depends on the guage.
    Aug 2006
    academy,tx
    1996 Trans am
    oh ok i was wondering what everyone was talking about wide band and narrow band .....whats the difference in wide and narrow ?
    Feb 2006
    Stock
    2002 Camaro
    Enjoy
    Narrow Band O2 Sensors began to appear on vehicles with the advent of fuel injection in the 1980’s. Their purpose was to monitor component degradation (i.e. fuel injectors, vacuum leaks) of vehicles as they accumulated miles. Their basic job was to let the computer know whether the vehicle was running at an air/fuel ratio of 14.7:1 under idle (ideal ratio for gasoline engines), moderate acceleration, and cruise conditions, and if it wasn’t, to “trim” the injector pulse-width to either slightly lean or richen the engine. When the computer is paying attention to the input from the O2 sensor, the engine is operating in a “closed-loop” capacity. Under heavier acceleration or wide-open throttle the computer ignores the O2 sensor because it requires an air/fuel ratio other than 14.7:1, which is outside the design parameters of the sensor. This is known as “open-loop” operation. The sensor lets the computer know if the engine is running above or below 14.7:1 by sending voltage to the computer in a range between 0 and 1 volt, usually sweeping between the two extremes of this scale. Traditional narrow-band air/fuel ratio gauges are simply a voltmeter for this signal. This can be seen by the repeated sweeping back and forth of the gauge in most idle, light throttle, and cruise conditions. To summarize, a narrow band O2 sensor is only able to tell a computer (or gauge, for that matter) whether an engine is operating above or below a 14.7:1 air/fuel ratio.
    Wide Band O2 Sensors where developed in the early ‘90s as vehicle manufacturers began looking to obtain air/fuel ratio information under all circumstances. This ranged from WOT to varying ratios, for example running air/fuel ratios leaner than 14.7:1 under cruise conditions. Volkswagen and Honda pioneered the development of the wide-band O2 sensors to provide accurate air-fuel ratios under these varying circumstances. They did this by broadening the voltage range in which feedback from the sensor was provided and making a linear scale that provided a fixed voltage that correlated to a specific air/fuel ratio. While the narrow-band O2 is still the most common type of O2 sensor installed on most new vehicles (for cost reasons), OEMs will still use wide-bands on many forced induction applications (or, in Honda’s case, on their “lean-burn” Civics).
    ls1 powered seabee sutie's Avatar
    oxnard, ca.
    red and black
    1999 Formula/WS6
    what should i expect to pay for a wide band?
    Feb 2006
    Stock
    2002 Camaro
    oxnard, ca.
    red and black
    1999 Formula/WS6
    worth it?
    Feb 2006
    Stock
    2002 Camaro
    same kit i have. if your planing on tuning it is a must
  1. Ultra gauge install
    By 10spokess in forum Camaro / SS
    Last Post: 01-15-2013, 06:51 AM
  2. Gauge install
    By LS1 Kahboy in forum Firebird / WS6
    Last Post: 04-21-2007, 07:30 PM
  3. Air/ Fuel Gauge Install
    By 99WS6MAN in forum General Help
    Last Post: 03-13-2007, 07:41 AM
  4. gauge install
    By TROYWS6X in forum General Help
    Last Post: 05-18-2006, 03:08 PM
  5. Gauge and pod install....
    By Mr. Luos in forum General Help
    Last Post: 08-25-2005, 05:43 PM
