    johnnyv
    Guest
    Ticking noise from the front when turning
    When turning the steering to the left while moving the car very slowly - I hear a ticking noise coming from the front passenager side.
    This always happenings when going in reverse to park my car:
    Drive straight - stop - go in reverse - move the car slowly while turing the wheel and I hear tick tick tick. (the steering wheel is not turned all the way)
    Any ideals on what's causing this?
    MOLESTER
    Guest
    its probably your axle, j/k. check your brake shield or possibly check for tire clearance if your running non oem wheels,
    johnnyv
    Guest
    I'll check the brake shield. I'm using OEM wheels (17" - 10 spoke). Funny thing is the noise only happens when I'm moving very slow (less than 5km/h) - anything faster - and I dont hear it.
    I'm also getting some creaky noises too with the ticking.
    near St. Louis
    navy blue
    2002 Z-28 Camaro M6
    Lube the brake caliper and pad contact points w/a high temp brake lube like Sil-Glyde.I agree w/ the other stuff to check also-but it could be a brake noise also.
    MOLESTER
    Guest
    om not sure how the abs sensor or whatever the hell is in ther but i guess just pull the wheel off and check for anything visibly wrong with the brakes
    Member DocEwww's Avatar
    Burlington, NJ / Syracuse, NY
    sounds normal for an F bod?
  1. Ticking Noise
    By iceman504 in forum General Help
    Last Post: 07-30-2012, 07:38 AM
  2. Replies: 1
    Last Post: 02-24-2008, 10:18 AM
  3. Some help with a ticking noise!!
    By fast enough Z28 in forum Camaro / SS
    Last Post: 04-04-2007, 06:11 AM
  4. ticking noise
    By Fire Chicken of Doom in forum Internal Engine
    Last Post: 01-21-2007, 02:31 PM
  5. bad ticking noise
    By B.A.N.A.T.A. in forum Internal Engine
    Last Post: 11-28-2006, 12:16 PM
