Results 1 to 10 of 10
Thread: ticking noise
    San Dieg-izzle
    black/red
    2003 SVT Cobra/1999 T/A
    ticking noise
    This is starting to bug the hell out of me.
    I have a 222/224/112 cam with a 566 lift.
    I have since developed a ticking noise on my valve train. Its not really running crappy or anything, its just annoying as hell.
    I have the correct length pushrods and everything and the lift isnt big enough to be slapping the valves on the pistsons, so what else could it be?
    It isnt something that happens all the time. Just every once in a while.
    Does anybody have any ideas?
    Its DEFINATELY coming from the top end of the engine, so my guess it like a loose rocker arm or something. Anyone have any other ideas?
    Im broke as hell, so Im hoping its nothing TOO serious.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Are you running stock rocker arms?
    Also can you narrow it done to one head or the other?
    Eagan MN
    66 GTO
    check valve lash clearence(top of stem and rocker arm) i rebuild my pa's 389 pontiac and put adjustable springs in, and i screwed them up had too much, that ticked, also check see what your oil pressure is because somtimes when theres insufficient oil it will make the tappets make clicking noises. goodluck
    Member mvvette97's Avatar
    leon iowa
    1997 corvette 00 WS6 TA
    Mine done the same thing so i had to replace the lifters
    MINNESOTA
    BLUE
    2000 SS CAMARO
    Def may be a collapsed lifter. In the past I have had 2 stick on me, and I poured a quart of ATF in the oil and both of them loosened up in about 5 minutes. I ran the car for about 2 more days and changed the oil. 25K later no problems. I am not saying it is the best fix, but it worked for me.
    San Diego
    Pull a valve cover off to see if there are any loose rocker's
    apopka, FL
    98 Camaro
    questions. when does it happen. first thing in the morning? does it go away when it gets warm? will it come and go as you drive? and is it rpm related, meaning does the noise speed up as you rev the engine?
    Evr sena bdgr killa snak? Roastem's Avatar
    Research Triangle Park, NC
    '99 Z28 M6
    Mine had the same problem. It turned out that one of the rockers must have needed adjustment. I loosened, then retorqued the rocker arms back to specs, and it went away immediately.
    Let me guess, when you have something close beside the car, like another vehicle at a stoplight, or at a drive-thru or something, is when you hear it clearly. It drove me nucking futz until I fixed it.
    Albury, Australia
    2001 HSV Clubsport
    i have this problem too. I have a 232/233 @112lsa cam but the ticking noise shits me. So i will loosen the rocker arms and retorque and let you know how i go
    Marylandistan
    2001 Trans Am (sold)
    My TR224 has ticked since it went in in 04. Did alot of searching and found it is normal. Haven't worried about it since.
  1. Ticking Noise
    By iceman504 in forum General Help
    Last Post: 07-30-2012, 07:38 AM
  2. Question: ticking noise
    By reaper ws6 in forum Internal Engine
    Last Post: 08-23-2011, 12:44 PM
  3. Some help with a ticking noise!!
    By fast enough Z28 in forum Camaro / SS
    Last Post: 04-04-2007, 06:11 AM
  4. bad ticking noise
    By B.A.N.A.T.A. in forum Internal Engine
    Last Post: 11-28-2006, 12:16 PM
  5. ticking noise
    By crashkev469 in forum GTO
    Last Post: 09-29-2006, 05:34 PM
