Results 1 to 3 of 3
    Junior Member jodmartyr's Avatar
    elkridge, maryland
    2000 trans am
    temperature gauge fluctuating
    im new at this so sorry if im postin this in the wrong place....but i just purchased a 2000 trans am and the temperature is randomly over heating and then returning to normal every once in a while, while i am driving. The car is def not overheating i know its just the gauge. Just wondering if any1 had anything similar to this happen?
    Senior Member MadSeason's Avatar
    Indiana
    Quote Originally Posted by jodmartyr View Post
    do you have any mods installed such as an underdrive pully, are you running the ac? is your air dam damaged? checked coolant? could be a sensor failing if you've checked everything else
    Senior Member
    Jacksonville, FL
    I'd take a look at the ECT sensor connector to make sure it's on tight and the pins look good. Doubt it's the gauge inself. SES light isn't on, right?
  1. Temp gauge fluctuating
    By redbird555 in forum General Help
    Last Post: 06-03-2010, 05:14 PM
  2. bloody temperature gauge
    By 1MileCrash in forum General Help
    Last Post: 08-04-2007, 08:19 PM
  3. temperature gauge fluctuating
    By jodmartyr in forum Firebird / WS6
    Last Post: 04-18-2007, 06:19 PM
  4. Temperature Gauge
    By steve01 in forum Internal Engine
    Last Post: 01-16-2007, 04:38 AM
  5. Temperature Gauge
    By steve01 in forum General Help
    Last Post: 01-12-2007, 04:53 PM
