Thread: Temperature Gauge
01-11-2007, 08:40 AM #1Junior Member
- Sep 2005
- california
Temperature Gauge
The temperature gauge in my 1998 Z28 is going all the way up to max on the gauge (engine not even warmed up). It starts out with a normal rise but continues to max. I read the temp through a scanner and the temperature is normal. I heard that the temp sender supplies the computer and the gauge. If the computer is correct I would think the sender is good. Bad gauge? Any thoughts on this would be appreciated.
01-11-2007, 06:46 PM #2
Did you recently put fluid in?
01-12-2007, 08:32 AM #3Senior Member
- Jul 2005
- Jacksonville, FL
I'd look at the wires/connector at the ECT sensor first. Fairly cheap and easy to replace the sensor, make sure you get one for a '98.
01-12-2007, 03:50 PM #4Junior Member
- Sep 2005
- california
temperature gauge
I did just drain and add fluids. I thought that was the answer (air pocket) but I let it run for several days thinking it would burp out. I take a good look at connectors and wires.
01-12-2007, 03:53 PM #5Slow'er'Ass
- Thornton, CO
I am kinda confused.
It starts out with a normal rise? That would mean the motor is warming up normal right?
But you said it isn't warmed up....
1998's were one of the few LS1 F-Body's with a fairly accurate stock temp. gauge. I can't say if it is sender or gauge. Dealer maybe? Or local LS1 tuning shop that can plug in some tuning software and read the temp the ECU sees.
01-12-2007, 04:53 PM #6
Damn I remember my 98 with a real guage ! ok im done
Temperature gauge not working
By LgndKller20073 in forum General HelpReplies: 9Last Post: 12-27-2011, 02:47 AM -
Temperature gauge not working.Help!
By J'stransam in forum General HelpReplies: 5Last Post: 04-14-2010, 07:20 AM -
bloody temperature gauge
By 1MileCrash in forum General HelpReplies: 16Last Post: 08-04-2007, 08:19 PM -
temperature gauge fluctuating
By jodmartyr in forum Stereo and ElectronicsReplies: 2Last Post: 04-20-2007, 10:06 AM -
Temperature Gauge
By steve01 in forum Internal EngineReplies: 1Last Post: 01-16-2007, 04:38 AM
