Thread: missfire when motor is cold?
04-15-2007, 10:18 PM #1Junior Member
- Apr 2007
- deer park tx
red- 00 camaro
my car hit 118,000 miles and now i get a misfire when the motor is cold.
i changed the fuel filter/i have 58psi pressure.
when i start the car cold i drive maybe a minute then it starts missing like crazy, ses light starts blinking and then after like a minute of missing it just clears up everytime and drives like normal?
gonna change the plugs tomorrow but that shouldn/t be it cause it would miss all the time.
04-17-2007, 12:58 AM #2
have you gotten the codes checked on it?
04-18-2007, 11:11 PM #3Junior Member
- Apr 2007
- Bellingham , WA
89 porche Red- 1970 Camaro RallySport
yeah have ur code or codes checked it should narrow it down to a cylinder for u. plugs might be the problem only if there really old, wires is a possibility but dont throw parts at it. check for good spark on all cylinders, check the plug gap on plugs and look at there condition if they are wet it could be fuel or oil, fuel will evaporate in mins but the oil will stay. another possibiliy is ur fuel injectors can be dirty or plugged , 2 options cheap injector cleaner or have them flow bench tested at a shop. the bottle cleaner isnt gonna do anything . last but not least compresion check if nothing above helps posiblity that u have a burned valve or a cracked head . but u say that it clears up so most likey not the case , im thinking ur ignition sytem if its an intermitten problem
hope this helps
04-19-2007, 10:49 AM #4
check your oxygen sensors I just had a problem with mine, the SES light would blink but it was because my plugs were all black due to a bad O2 sensor. Bought a new O2 got rid of the SES
04-19-2007, 06:03 PM #5Impounded
- Feb 2007
- Pa
Red- 99 TA
worn valve seals
04-19-2007, 06:34 PM #6
My guess would be an intake gasket leak letting unmetered air in. Would go away when things expand.
04-19-2007, 06:39 PM #7Impounded
- Feb 2007
- Pa
Red- 99 TA
worn valve seals
04-20-2007, 09:08 PM #8Junior Member
- Apr 2007
- deer park tx
red- 00 camaro
code said cyl # 6
i repaced the o2's and it got alot better
now it will only do it when the engine is warm and i shut it off and start it back up. now it only lasts about 5-10 seconds and at very light throttle positions.
doesnt set off the ses light anymore but it still missfires a little then clears right up and i can drive like normal
im gonna check it out a little more tomorrow and change the plugs
thanks for the replys guys
04-21-2007, 03:30 AM #9Impounded
- Feb 2007
- Pa
Red- 99 TA
check the valve seals!
Help!!! Missfire
By tcondra in forum General HelpReplies: 5Last Post: 07-26-2009, 09:08 PM -
Motor Oils and Cold Temperature Performance
By CompSyn in forum Internal EngineReplies: 0Last Post: 12-03-2008, 01:58 PM -
Help: LT1 Pinging/ Missfire
By WhiteThunderZ28 in forum LT1Replies: 0Last Post: 04-19-2008, 08:03 PM -
HELP!! Missfire
By rajiv1998 in forum General HelpReplies: 16Last Post: 03-24-2008, 05:50 AM -
help having problems car missfire
By william SS in forum Internal EngineReplies: 5Last Post: 06-10-2007, 10:20 AM
