    Member william SS's Avatar
    Tulsa, OK
    2001 camaro SS
    help having problems car missfire
    Went to start my car yesterday and all of a sudden its starts missing like crazy. Computer code read open #1 cyclinder misfire. So i took it to a chevy dealership and they said left bank all 4 injectors quit and showing open circut. Any idea what may of cause this and how to fix it?
    Aug 2000
    Indy
    they gave you nothing else to go on ?
    Member TACE02's Avatar
    ASC #753
    2002 Collector's Edition
    All 4 on the left side quit??? do you have a SES or CES light illuminated. you may have a bad 02 sensor or cat. I see you have LTs with ORY. you did install extensions so your front 02s would reach, correct. did you get it tuned or install rear 02 sims.
    Member 2001hawk's Avatar
    South Carolina
    Black & Black
    2001 Firehawk & 2002 WS-6
    I think we need to know if you have done anything to it recently? How many miles are on it? etc. You might try starting with checking grounds.
    Tulsa, OK
    2001 camaro SS
    Yes all 4 went out on the left side turns out it was because i blew a fuse but dont what caused the fuse to blow so i replaced it and now everything works fine. But since i didnt actually find the problem and took the shortcut to fixing it i supposed it could possibly blow again. But i wasnt getting any ses or any thing like that. When i went to work it was fine, when i started it up after work it wasnt fine. It was like it could barely beath was weak. Oh nothing has been done to the car in 4 months and it has 40,600 miles on the clock.
    South Carolina
    Black & Black
    With it having blown a fuse I would say that narrows it down to a wiring issue. Did you wash the car or clean the engine bay recently? Most of the wiring for the injectors should be in the convoluted tubing so I highly doubt chaffing would cause a short along that length of wire. That narrows it down a little more. Bad news is that most gremlins hide but never go away until you find the cause. So you are right in changing the fuse being only a shortcut.
  1. Help: Cylinder 8 Missfire
    By davidz28 in forum General Help
    Last Post: 08-26-2011, 09:37 AM
  2. missfire on cylinder 6
    By lsmaxxed in forum General Help
    Last Post: 06-30-2011, 01:57 PM
  3. Help!!! Missfire
    By tcondra in forum General Help
    Last Post: 07-26-2009, 09:08 PM
  4. Help: LT1 Pinging/ Missfire
    By WhiteThunderZ28 in forum LT1
    Last Post: 04-19-2008, 08:03 PM
  5. HELP!! Missfire
    By rajiv1998 in forum General Help
    Last Post: 03-24-2008, 05:50 AM
