Results 1 to 14 of 14
Thread: Bad vibration at high speed?
04-13-2007, 10:56 PM #1
Since I got my Formula it has had a vibration at high speed. Once you get up past 85-90mph the whole car starts to shake. I got the wheels balanced and still had the same thing. Thought it might be a bad axle or carrier bearing. Rebuilt the whole rear down to new differential and axle shafts. Same thing. Thought I had a couple of bent rims. Changed the wheels and tires. Same thing. Any thoughts. Shocks, wheel bearing, tranny or motor mounts? It's weird because the car is solid as a rock until you get over 85 or so. It also feels like the engine might be breaking up and causing it sometimes. Maybe a bad harmonic balancer or something? It has new plugs, wires, fuel filter, air filter, etc. Any thoughs would be appreciated. Thanks.
04-14-2007, 04:14 AM #2Member
- Apr 2006
- North Canton, OH
Light Metallic Pewter- 2000 Corvette Coupe
Have you had it checked on Roadforce Balance Equipment?
04-14-2007, 08:37 AM #3
04-14-2007, 08:47 AM #4Single Malt
- Ft. Lauderdale, FL
Sebring Silver- 2000 CamaroSS
Have you considered a bad tire???
Had a ply separation that wasn't visible once.....wouldn't give a shake untill at a certain speed
Could try a different set of tires to eliminate the possibility
04-14-2007, 11:04 AM #5
as I said in my original post the car has a brand new set of wheels and tires. It had the same vibration with both the new and old tires and wheels.
04-14-2007, 11:18 AM #6
DRIVESHAFT.........
You need to check it with a dial indiacator if possiable. Or as cheap as it is I would take it out real quick by only jacking up the rear so you don't loose any fluid and run it over to have it balanced. I get them dome for $30 out here.Don't be afraid of the bottle!!! Be afraid of your tune!!!
04-14-2007, 01:04 PM #7
04-14-2007, 01:14 PM #8Impounded
- Feb 2007
- Pa
Red- 99 TA
do you have the steel driveshaft with the harmonic balancer or the aluminum shaft?
04-14-2007, 02:33 PM #9
+1 on drive shaft. Also check whether is is speed, rpm or gear specific.
04-14-2007, 03:10 PM #10Impounded
- Feb 2007
- Pa
Red- 99 TA
i picked up a vibration after installing a new auburn carrier,swapped it out for a torsen and the vibration was gone.i looked at the auburn carefully and couldn't find any signs it was balanced in any way from the manufactuer.what carrier is in your formula?
04-15-2007, 12:45 PM #11
I have an aluminum driveshaft. The carrier is a new Auburn. I recently replaced an old Auburn and it had the same vibration with both, but there are tons of Auburn cars that don't have this problem.
04-15-2007, 01:01 PM #12Member
- Mar 2007
- NC
NBM- 1998Z28
I'll go with axle bearings. I had a bad vibration and when I went with a rearend rebuild/upgrade to 3:73s the vib went away. All I ever saw wrong was bearing races that were out of round.
04-15-2007, 02:12 PM #13Impounded
- Feb 2007
- Pa
Red- 99 TA
see if someone will let you borrow thier steel drive shaft with the balancer.i'll never buy another auburn after my experiance with them.
04-15-2007, 05:46 PM #14
Hot Rod To The Rescue - High-Speed Driveshaft Vibration
By Ed Blown Vert in forum General HelpReplies: 0Last Post: 10-01-2014, 02:11 AM -
Help: vibration increases with speed under heavy accel.
By Camaroguy98 in forum DrivetrainReplies: 10Last Post: 11-22-2012, 03:38 PM -
Land Speed Racers - High-Speed Bombers
By Ed Blown Vert in forum Almost Anything GoesReplies: 0Last Post: 11-16-2010, 05:20 PM -
High speed cornering
By bossho in forum Suspension and HandlingReplies: 8Last Post: 11-09-2009, 04:21 PM -
high idle speed ???
By paq in forum General HelpReplies: 4Last Post: 04-07-2007, 06:50 AM
