Thread: High idle?
04-11-2007, 05:55 PM #1
High idle?
My Formula idles arounds 1050rpm. Why would it idle so high? It did it stock and it now does it with headers, exhaust, etc. as well. I haven't found any vacuum leaks or anything. Any ideas?
04-12-2007, 06:57 AM #2
Is this with the engine cold or warm?
04-12-2007, 02:52 PM #3
04-12-2007, 03:38 PM #4
check the pcv hose that connects to the intake. it rots on the bottom side of it where you can't see it. the short hose between the intake and pcv valve.
other than that, was the car tuned? maybe the tuner set the idle tables that high for some reason.
next thought is the previous owner turned the idle set screw on the TB.Cold Air Intake, Muffler Delete, Vinci High Performance Dual Valve Springs, Hardened Pushrods, Yella Terra 1.85 Rockers, Some Hydropdipped Stuff, Strut Tower Brace, Some SS Badges, boost/vacuum gauge, fuel pressure gauge, some checkered stripes, drilled/slotted rotors, ZL1addons Stealth wickerbill, Ruxifey LED side markers
04-12-2007, 05:03 PM #5
I'll check the PCV hose. I would highly doubt the car has ever been tuned. It was BONE stock when i bought it.
idle issues... idle high. unplugged tps runs good?
By okiels1 in forum Firebird / WS6Replies: 2Last Post: 12-31-2016, 03:36 AM -
high idle
By Spikito in forum External EngineReplies: 7Last Post: 07-06-2011, 09:42 PM -
Question: High Idle
By 00hawk109 in forum General HelpReplies: 20Last Post: 05-10-2011, 01:45 PM -
high shift points & high idle
By Red 99 T/A in forum General HelpReplies: 5Last Post: 07-26-2010, 08:04 PM -
High idle
By kev70ss in forum External EngineReplies: 3Last Post: 01-27-2008, 01:40 PM
