    Aug 2006
    North Eastern Md
    99 SS Convertible
    best cam to pass Maryland emissions
    I am getting long tubes installed shortly along with the cam, but can anyone from Md let me know how big I can go, and still have no issues with the emission guys. Btw, I have a M6 and everything is stock. Thanxs!
    The Bandit Wesman's Avatar
    NJ
    SGM
    1998 Trans Am WS6
    I didn't think Maryland even had state inspection??
    Anyway, if they are anything like most other states, the size of your cam will be irrelevent - because they don't check tailpipe emmissions. What they do is plug into the OBD2 port under the dash, and pull the codes and emmissions status. So as long as your cam doesn't throw any codes (it shouldn't) you should be fine. Your best bet is to get a tune, and have them remove the AIR/EGR systems through the computer and tune out the reat O2 sensors. That way, even with no emmissions systems or cats, the computer will still report that everything is operating normally
    Aug 2006
    North Eastern Md
    99 SS Convertible
    really . . . it's that easy? So you're saying you can cheat with an external computer, LS1 edit for example, and it tunes or removes codes that my car would naturally show to the emissions guys. So why all the hype about people freakin out about their cars failing cause they threw in an aftermarket cam that didn't pass? What's the purpose of this test anyway, if you can beat it?
    NJ
    SGM
    1998 Trans Am WS6
    Quote Originally Posted by redfire99ss View Post
    Yes, pretty much. You can tune out the emmissions systems with the software, no problem.
    Basically the state inspection checks to make sure that the computer isn't throwing any codes. Instead of physically checking the exhaust emmissions, they trust that the computer (since its OBDII) will provide them with codes if something is malfunctioning. By tuning out the emmissions systems, the ECU won't throw any codes, and therefore it will pass the OBDII test. However, you could have an issue if they do a visial inspection (no cats) or if they realize that the car is supposed to have EGR/AIR and its coming up in the system as "not ready", since it was tuned out.
    You will more than likely be fine though as long as the ECu isn't throwing any codes (SES light off).
    Member 2001hawk's Avatar
    South Carolina
    Black & Black
    2001 Firehawk & 2002 WS-6
    Everything matters how strict the particular state is about the testing. When I was in the military, I was stationed in Utah. They were pretty strict about stuff. They had the safety and emissions test and both had to be done and certified at the county testing facility. They didn't do the visual check because if you didn't have the cats there is no way to pass. I can remember here in SC when I first started driving we had the checks but any mechanic's shop could say they checked it out. We haven't had testing in almost ten years now. LOL
  1. pass emissions
    By Z28_Driver in forum External Engine
    Last Post: 03-23-2010, 08:32 AM
  2. Can 02 sims help me pass emissions?
    By GottaHaveLS1 in forum General Help
    Last Post: 06-14-2007, 11:56 AM
  3. Can you pass emissions w/Trex?
    By Toes in forum Internal Engine
    Last Post: 10-30-2006, 05:36 PM
  4. Will i pass emissions?
    By GottaHaveLS1 in forum External Engine
    Last Post: 05-28-2006, 09:41 AM
  5. Will a catted y pass emissions?
    Last Post: 05-16-2006, 04:47 AM
