Results 1 to 10 of 10
Thread: pass emissions
03-19-2010, 11:52 AM #1
pass emissions
Does anyone on here have Lts, an aftermarket y (either catted or not) and a computer tune that will pass the plug-in test? I would like to know as I am considering headers and would like to know if the rear O2 delete and/or AIR delete will show when the tester plugs into the computer. Anyone?
03-19-2010, 02:10 PM #2Exalted Cyclops
- Feb 2007
- San Diego, CA
You need to have a tuner (or someone with the correct software) turn off the rear O2's for the SES light to go out.
I have LT's, no cats, no AIR and duals dumped at the axle. I pass the plug in test as I've had it all tuned out.
I take it you don't have to pass a visual?
You also will need to pass the gas cap vacuum test.
03-19-2010, 03:29 PM #3
I'll let you know in a month or two, lol... I got LT, catted Y and frost tune. Will have to see.
03-20-2010, 10:01 AM #4
Your tunner can do some tricks, mine passes NP
03-20-2010, 03:22 PM #5
I don't have to pass any emissions here right now. Just looking to the future. Is the gas cap test just to check for a vapor leak?
03-20-2010, 03:34 PM #6
The visual test would be to check for the cats i'm assuming. Do they check for the air system? Would this system make sense? LTs, catted y, deleted rear O2s and deleted AIR system.
Maybe have the high-flow cats as i've always driven old vehicles and I like not smelling gas at a traffic light with the Camaro. Should the AIR system be left intact with a aftermarket catted y?
03-20-2010, 05:40 PM #7
Its good to know someone,
03-23-2010, 01:29 AM #8
I have a 98 Tran Am w/ Ly's and a ORY and the rear O2's tuned out along with the egr tuned out when I swapped in the LS6 intake. I pass the emmisions I just got to a small place where my buddy knows the guy so there's no visual inspection. Long as the computer is ok I get my sticker.
03-23-2010, 07:23 AM #9
good to know the right person
03-23-2010, 08:32 AM #10
Thats what I wanted to know. If it works in other states it will work if they start it here. Thanks for the help.
I think I will get the catted y just to reduce the smell as I have an old truck without cats and it stinks when idling.
Any opinions on LPP headers and catted y pipe?
Pass emissions testing with APS TT?
By srtricky in forum Forced InductionReplies: 6Last Post: 10-15-2008, 07:09 PM -
Can 02 sims help me pass emissions?
By GottaHaveLS1 in forum General HelpReplies: 8Last Post: 06-14-2007, 11:56 AM -
Can you pass emissions w/Trex?
By Toes in forum Internal EngineReplies: 3Last Post: 10-30-2006, 05:36 PM -
Will i pass emissions?
By GottaHaveLS1 in forum External EngineReplies: 3Last Post: 05-28-2006, 09:41 AM -
Will a catted y pass emissions?
By GottaHaveLS1 in forum External EngineReplies: 0Last Post: 05-16-2006, 04:47 AM
