Thread: Trouble code, need help
04-10-2007, 07:54 AM #1
The check engine light came on in my 99 T/A. I bought an OBDII code reader and the code PO442 came up. The book says that this is Evaporitive EmissionControl system leak. I also noticed the car makes a whining noise kind of like a small vacume cleaner from the drivers side while at idle. As you rev it up the noise goes away, at idle it comes back. Does anyone know exactly what this code is? Thanks
04-11-2007, 10:51 AM #2Senior Member
- Jul 2005
- Jacksonville, FL
Buddy of mine had P0442. He tried replacing the gas cap first, kept coming back - ended up getting the system pressurized with smoke at a shop to find it (was a small leak in the gas fill tube somewhere). Yours could be something different. www.gearchatter.com/viewtopic8854.php Whining/vacuum cleaner noise on start up sounds like the air pump, but should go off by itself after a couple minutes.
04-28-2007, 11:43 AM #3Member
- Oct 2005
- calif.
Whining noise is the air pump going on/off for the 1st couple of minutes at start-up--
Evap codes are usually gas cap or tank vent hose---you could have a leak in one of the hoses or one may have fallen off check them all from the routing from tank to engine compatment
04-30-2007, 07:57 PM #4Member
- Apr 2007
- San Diego
Red- 2002 T/A
+2
Have you filled up since this code appeared?
Tighten the gas cap and reset the codes.
See if this helps.
Remember not to leave the engine running or the ignition in the on position while refueling.
Trouble code
By chevy2001 in forum GM TrucksReplies: 0Last Post: 10-31-2007, 07:57 PM -
Trouble Code Help?
By SS_Crazy in forum Camaro / SSReplies: 1Last Post: 05-27-2007, 11:02 AM -
Trouble Code
By zachjl in forum General HelpReplies: 1Last Post: 04-24-2006, 12:50 PM -
Trouble code help
By GLUMAKER in forum General HelpReplies: 5Last Post: 04-10-2006, 05:37 PM
