    SF Bay Area
    2002 Trans Am WS6 M6
    Trouble code help
    My car just threw the code P0300 (engine misfire detected). What course of action should I take? I have an HPP3 if that helps.
    Senior Member
    Jacksonville, FL
    My car has thrown that at WOT a couple times over the years, I just cleared it. If you were just driving along and it came on I'd look at plugs/wires first.
    SF Bay Area
    The light was flickering on and off when I was doing a 0-100 run. I just reprogrammed the computer and took it for a drive and everything seemed to be fine. Very smooth and no high-rpm knock.
    Senior Member
    Jacksonville, FL
    Thought you might have been getting on it. Flashing SES is a misfire though, mine didn't do that - still might want to look at plugs/wires if it comes on again.
    Bragg NC
    Met. Sunset Orange
    01 SS
    I would check over your plugs and wires and make sure everything is tight and looks good then i would reset the comp and see if it comes back.
    Can you tell if its miss firing? rough idle or just not acting like it use too?
    J
    SF Bay Area
    It's been running like a champ since I reprogrammed it, but I'll take your advice and take a look at the ignition components.
  1. Trouble code
    By chevy2001 in forum GM Trucks
    Last Post: 10-31-2007, 07:57 PM
  2. Trouble Code Help?
    By SS_Crazy in forum Camaro / SS
    Last Post: 05-27-2007, 11:02 AM
  3. Trouble code, need help
    By wicked1 in forum Computer & Tuning
    Last Post: 04-30-2007, 07:57 PM
  4. Trouble Code
    By zachjl in forum General Help
    Last Post: 04-24-2006, 12:50 PM
