Results 1 to 16 of 16
Thread: Switching from runflats
04-10-2007, 01:37 AM #1Junior Member
- Mar 2007
- hayward/castro valley, CA
Silver/Pewter- 2000 C5 Corvette 6psd
As my runflats are approaching near balding, im thinking about going with non runflat tires as i hear they perform better in pretty much every category. Lighter, cheaper, better handling, better traction etc. This may be a dumb question, but if u do a decent amount of driving on ur C5, well what do u do if u get a flat? carry a spare with a jack?? Or might it just be in my best interest to get runflats again.
04-10-2007, 03:00 AM #2Junior Member
- Jan 2007
- Lake Geneva, Wisconsin
millenium yellow- 2000 corvette
I have AAA. so if I have any tire issues I call for a tow on a flat bed.
04-10-2007, 11:41 AM #3Junior Member
- Mar 2007
- Virginia
black/blue/red- 2007 C6Z/2006 C6Z/2006 C6
Screw the run-flats! I carry a powered pump with me in my vettes. Better performance all around. Go for it!
04-10-2007, 01:45 PM #4Junior Member
- Knoxville, TN
Torch Red- 2000 Corvette
04-11-2007, 04:46 AM #5
yeah I run non runflats, just carry a plug kit and a small pump. odds are you won't have to use it.
04-11-2007, 05:11 AM #6
I also carry a tire plugging kit and a small 12 volt compressor to use with my
Kuhmo run flats,since they're only rated for 50 miles at speeds below 50 mph with no air pressure.
My next set of tires will also not be run flats.
04-11-2007, 09:54 AM #7Detailing + Design
- Pittsburgh, PA
does it mess with the computer if you yank the run flats...doesn't the computer sense what kinda air pressure is in the tire...or doesn't it matter if it's run flat or not?
04-11-2007, 02:20 PM #8Junior Member
- Mar 2007
- Virginia
04-11-2007, 02:29 PM #9
the air pressure is the same doesn't matter what kind of tire. Just how much air you put in them. My sensors work great.
04-12-2007, 01:30 AM #10Junior Member
- Mar 2007
i have a replacement set of the eagle f1s (which are almost bald) on my car, do u know how far i can drive those on empty before its clobbering time? I was told around 250-300 miles under 55 mph but now im having doubts. Also, as far as a tire patch kit and small pump, any of you guys have links for high performance tires (i dont wanna just by any ol' tire patch kit). Next question, if i switch away from runflats, which tires would you guys suggest?
I was looking at the toyo proxes, not just because theyre pretty affordable and i wont feel too bad going through lots of them, but ive been told by some theyre nice, by others, they are way too soft.
04-12-2007, 05:46 AM #11
I forgot to mention that plugging the tire is only for a temporary repair that allows you to drive with the tire inflated until you have a permanent repair made.The heat from flexing that's generated, while running flat, ruins the runflat tire,making it unrepairable.The recommended repair for any radial tire is to patch it on the inside liner.
04-12-2007, 03:53 PM #12
the plug is just temporary, whenever you can get it patched and it doesn't really matter what brand of patch, I do it myself, but I'm a salty dog when it comes to working with tires, (Have a 4000 acre cucumber farm and a tire machine) I got some nitto 555 from discounttire.com they have good prices and a good selection, there is also tirerack.com its a good site aswell. Or just go to a tire shop and get a quote.
04-13-2007, 10:51 AM #13
04-14-2007, 03:15 PM #14
You can check here for brands and specs that the Tire Rack carries.
http://www.tirerack.com/tires/Compar...Y&RunFlat=None2017 A8 Z06 - 10.48 @ 132.3 mph
04-14-2007, 04:02 PM #15Junior Member
- Nov 2006
- Charleston, SC, but originally from Gainesville, FL
SILVER- 2002 Z28
Ditto most comments above.
I bought a ZO6 tire repair kit (you can get something much cheaper at AUTOZONE or something) and I carry a cell phone. The run flats are great for their purpose, but I wanted performance, traction and over all better tire options. I have made cross-country trips and numerous trips to and from Jacksonville, FL and never had a problem, but the security of the repair kit does keep piece of mind.
Micah
04-18-2007, 05:33 PM #16Junior Member
- virginia
I ditched my run craps on my '01 and went with the Eagle F1 GS-D3.. much quieter and better ride.... also bought a Continental tire inflator kit from there ($79) which has a sealant that is safe to use with the sensors.. and an air pump
F*S* Pair of Rear Stock Runflats 9/32 Photos >>>>
By widget in forum Parts For Sale / TradeReplies: 1Last Post: 10-03-2007, 10:53 AM -
Switching to a T rex
By krusemj in forum Internal EngineReplies: 6Last Post: 03-05-2007, 06:53 AM -
275 40 18 goodyear runflats
By 4MULAV8 in forum Parts For Sale / TradeReplies: 3Last Post: 08-08-2006, 08:59 AM -
Corvette Goodyear runflats?
By MrWillys in forum CorvetteReplies: 4Last Post: 05-16-2006, 04:56 PM -
Gauging interest: Set of 4 Goodyear F1 Runflats
By 00 NBFRC in forum Parts For Sale / TradeReplies: 0Last Post: 03-12-2006, 11:02 AM
