    Member krusemj's Avatar
    where ever the army wants me to be
    artic white
    2001 WS6 Trans Am
    Switching to a T rex
    Hey guys like the title says I am thinking of switching from the Comp 224 cam the to T rex. What kind of gains do you think I will see. Right now I am putting out 410 whp. The car has patriot stage 2 ls6 heads and all the supporting mods. Just wondering how much of a gain I should expect if I decide to go through with this.
    “The democracy will cease to exist when you take away from those who are willing to work and give to those who would not.”
    Thomas Jefferson
    Aug 2006
    29 palms
    2000 pontiac TA vert
    I had a 224 cam and went to a t-rex as well. Best cam I have ever had. But with a 4400 converter I know it wont dyno for shit. are you an A4 or M6
    artic white
    2001 WS6 Trans Am
    It is a M6. I shouldnt have PTV cleareance problems should I.
    Gold Member BlwnCamaro's Avatar
    Las Cruces,NM
    1998 Z28 Camaro
    Quote Originally Posted by krusemj View Post
    I think you should see at least a 40 hp difference in the upper rpm range with the t rex upgrade. Plus thunder racing advertises that cam to work with stock piston to valve clearance but recommends checking if you have aftermarket heads with a different height or with thinner head gaskets. You mentioned you have patriot heads you may want to consult to see if they have the same installed height but if there is any doubt better to pull the heads and check with the old clay method just to be safe.
    Jesus died to save you! Killer_bluebird's Avatar
    North Olmsted, OH
    It is a M6. I shouldn't have PTV clearance problems should I.
    Since they are Stage 2 you will probably need to flycut. If they were stage 1, with stock valve sizes, you might have been ok but I would have checked PTV clearance anyway.
    2000 NBM Camaro Z28
    Mods:
    SLP Lid & K&N, AHR Headers + 3" catted Y and Mangaflow, !EGR, !AIR, BMR CM STB, ST Front 35mm and Hellwig Adj. Rear 22mm Swaybar, Adj. Rod/Rod PHB, Koni SA's, Ground Control Springs & Adj. Ride height, and HPTuners.
    Aug 2006
    29 palms
    you will need to flycut
    DFW
    '18 CTS-V
    '13 ZL1
    Patriot welds up their chambers they do not mill down like other head companies do. I would call Patriot Performance and talk to Gunnar to make sure. also a key part that you have left out is if you have the 64cc or the 59cc chambers. call them, and they will be able to set you in the right direction. regardless i would run nothing less that .100" of piston to valve clearance, so if that means you need to flycut after a clay test, i would for peace of mind...
    2013 ZL1: °°590rwhp/576rwtq°°
  1. Switching to synthetic oil? Should I?
    By BlackPearl in forum General Help
    Last Post: 04-06-2012, 09:03 AM
  2. Switching modes!!
    By REVNORR82 in forum Almost Anything Goes
    Last Post: 10-19-2010, 12:25 PM
  3. switching from ls1 to ls6 intake
    By dfillmore827 in forum External Engine
    Last Post: 03-24-2009, 10:24 AM
  4. Tv switching ove to HD... this is funny... :D
    Last Post: 10-27-2008, 08:50 AM
  5. switching from syn back to reg oil
    By CamaroSSx1999 in forum Internal Engine
    Last Post: 09-02-2005, 03:47 AM
