Page 1 of 3 123 LastLast
Results 1 to 20 of 58
    Senior Member
    PA
    07 MAZDASPEED6 GT
    Exclamation I want to buy my 1st handgun...
    I'd like to get a 9mm. I know nothing about guns other than I like shooting them.
    So what are some good and relative inexpensive hand guns that would be good for me?
    '07 MAZDASPEED6 GT
    '96 Mystic Cobra #5615
    230,55,147 91Z28's Avatar
    Houston
    Cyclone Grey Metallic
    2006 GTO
    Good luck, NJ isn't exactly the easiest place to obtain a hangun.
    Senior Member nitrox28's Avatar
    Lexingon Kentucky
    1997 Grand Cherokee
    1999 Firebird.
    If it's your first, I'd buy a .357 magnum and shoot .38 specials until you're more comfortable then move up to .38+p or .357 loads. 9mm has very light recoil so that won't be an issue. If I'm not mistaken NJ has a TON of bullshit gun laws so I can't advise you on any of that. What are you gong to use it for? I always recommend that a novice start with a revolver and learn the basics. You can trade up anytime you want.
    2nd last of the lt1s EVAR 94z28l's Avatar
    colorado
    purple pearl metalic
    1994 Z28 Camaro
    i'd reccommend a .45 hand cannon dirty harry style
    Member Mjolnir's Avatar
    Feb 2007
    Arizona
    White/Black
    1999 Camaro z28
    dude 9mm is a great starting hand gun, cheap ammo. It depends on what you want the gun for.
    if your going to take it to the range alot id recommend a glock, its a great pistol, very reliable.
    I also like H&K USP .45 if your looking for a little bigger round.
    Pontiac Addict 01RaptorTA's Avatar
    Northern Indiana
    Black on black
    2003 Bonneville SSEi S/C
    Im gunna have to go with the 50 cal turret off an Abrahams tank...
    I mean.. +1 to glock
    Houston
    2006 GTO
    Quote Originally Posted by 94z28l View Post
    Dirty Harry used a .44 magnum. Some have claimed that the actual gun shown in the movie was a .41 magnum but the guns are identical so no one knows for sure.
    Dec 2002
    n/w chicago
    2000 nhra edition formula
    go to a local gun store and check out all the 9mm they have. the most important thing about getting a gun is that it fits in your hand. comfort and feel is the most important thing.
    a few bolt ons, 379 rwhp
    11.96 @113.25
    doesn'tplaywellwithothers superchargedblackgto's Avatar
    Mayberry....(Indiana)
    2004 GTO
    I have a 9mm beretta, I like the gun very well, strait shooter, but if you want it for home defense? I would go with a .45, because the 9 has more velocity and will go through several walls before it stops..It also lacks the knock down power of the .45...but it is the military standard so rounds are cheaper...just some things to keep in mind. beretta has been making guns for over 400 years, they are hard to beat for reliability, and acuracy.
    Senior Member
    PA
    07 MAZDASPEED6 GT
    Quote Originally Posted by nitrox28 View Post
    I already know I like shooting a 9mm. That is what I want.
    It will be used to go to the range & for protection should anyone ever try to rob me.
    Impounded eddierox's Avatar
    alabama
    2004 Z06
    I would opt for a 40 mm Mini *Gattling* Gun in either tripod or handheld.
    Just close your eyes, squeeze the trigger and let loose.
    Great at vaporizing unwanted artifacts.
    Dec 2004
    SS: NBM, tan top
    1998-SS, 2010 Jetta TDI
    u need one of these
    thats me ^
    alabama
    2004 Z06
    Quote Originally Posted by ss~zoso~ss View Post
    u need one of these
    thats me ^
    Are Masons allowed to listen to Led Zepplin?
    DFW
    '18 CTS-V
    '13 ZL1
    Quote Originally Posted by Mjolnir View Post
    that is the handgun i own except mine is the H&K USP .45 Compact. it's a great firearm...
    alabama
    Gray
    2012 Challenger R/T
    it depends on if you want it for defence or shooting ... But .45 is one of the best ... One shot and they dont get back up..
    Senior Member whitelightnin99's Avatar
    SC
    i have a $150 Hi point 9mm, its kind of bulky but its only for home protection. never jammed or let me down so far
    Lexingon Kentucky
    1997 Grand Cherokee
    1999 Firebird.
    Thumbs down
    [QUOTE=eddierox;694172]I would opt for a 40 mm Mini *Gattling* Gun in either tripod or handheld. [QUOTE]
    There is no such thing as a "handheld" M134 minigun. The gun in that picture isn't real and the one used in the movie Predator is a Hollywood movie BS gun. (they don't sound like that either) The machinegun shoot is coming up next weekend at Knob Creek and you can buy a M134 there with the right paperwork for the low low price of $150,000. www.machinegunshoot.com
    alabama
    2004 Z06
    Quote Originally Posted by eddierox View Post
    Any particular reason you needed to wake me out of my little pipe dream I had going?
    - = LR = - grandkodiak's Avatar
    x
    Get a Glock 31 in .357 Sig. Its a 9mm in a 10mm case, and uses the same EVERYTHING otehr then barrel as the 40sw, so for $100 or less you can swap in a 40sw barrel... and they make a .22lr kit for it, so buy 1 gun and you have 3 ammo options. 357 for penetration, 40 for knock down 22 to save money. Ammo is about $15-25 for 50 depending on load/company, but with the 22lr its about $2.50 for the same amount... shoooot ALL day and work on your trigger work. any idiot can aim weapon sights, accuracy and ability is ALL in the trigger pull.
    i'm in long branch, ever want to go to shoreshot (exit 88 on aprkway) lemme know, show ya around the different guns.
    glocks are cheap, extremly reliable, easy to clean, retain value, no exposed hammer, trigger is exactly the same EVERY pull, no da/sa trigger pulls to get used to, rediculously short trigger reset for even more accurate shots or rapid fire like a full auto... i could go on and on. get a glock.
  1. Got my 1st handgun
    By JayTA98 in forum Gun's & Ammo
    Last Post: 05-06-2015, 04:14 PM
  2. First handgun
    By kronik in forum Gun's & Ammo
    Last Post: 04-13-2011, 02:58 PM
  3. Handgun Lights
    By Mr.C&I in forum Gun's & Ammo
    Last Post: 08-19-2010, 05:03 PM
  4. My next new handgun
    By opie in forum Gun's & Ammo
    Last Post: 03-10-2010, 07:34 PM
  5. Handgun laws
    By Mr.C&I in forum Almost Anything Goes
    Last Post: 02-11-2009, 07:21 AM
