Results 1 to 10 of 10
Thread: Front driver side blinker
04-07-2007, 05:34 AM #1Slow'er'Ass
- Thornton, CO
Socket is rusted out and has all kinds of corrosion on it. Works sometimes.
Anyone know if I can get a new socket or do I have to replace the entire section of the cars wiring to get a new peice there???
04-07-2007, 07:15 AM #2The Pulse of the Maggots
- Apr 2006
- Fayetteville, NC
NBM- 1999 Trans Am WS6
both of my front blinkers did the same thing. all I did was I took the bulbs out and let them air dry, then I cleaned the sockets out really really good. then I went to advanced auto and bought some light bulb grease(thats what it is actually called) put it on the ends of the bulbs and eversince then I havent had any problems. try that, I think it should work. hope this helps!
04-07-2007, 09:15 AM #3Slow'er'Ass
- Thornton, CO
Sounds good. I will give it a shot.
04-07-2007, 03:31 PM #4The Pulse of the Maggots
- Apr 2006
- Fayetteville, NC
if you can remember, let me know if it works for you!
04-07-2007, 03:34 PM #5Slow'er'Ass
- Thornton, CO
Will do.
Recommendations of what to use to clean out the socket?? Battery corrosion stuff?
04-07-2007, 06:59 PM #6
04-07-2007, 09:38 PM #7
cool, I am also going to use this advice since my passenger taillights are dim due to corrosion.
04-08-2007, 12:17 AM #8
definately try cleaning as advised already, but in response to your question--yes you can buy the sockets. I ended up buying both front turn signal housings (mine were cracked letting the water in) and both sockets for under $100 at ABC. Straight forward install--just solder and heat shrink in leads from new sockets to car wiring.
04-08-2007, 04:52 AM #9
If you get new lenses (which is a good idea, because you probably have leaks if your sockets are corroded) put a bead of silicone around the area where you'll see GM's gasket. The new lenses look so much better too, nice and clear, big difference over the old ones. Think I got em' both online for around 76 bucks. Went with those clear/silver Sylvania turn signals too.
04-08-2007, 08:54 AM #10Slow'er'Ass
- Thornton, CO
I have my signals blacked out. I may pull them out and use some black silicone on them, but I don't think I need to replace them.
Plus, the only time they get wet is when I wash the car.
Driver Side blinker doesnt work
By barryz in forum Stereo and ElectronicsReplies: 7Last Post: 08-15-2016, 08:52 AM -
Does anyone have a driver side front fender for sale?
By wickedbeast in forum Parts Wanted / TradeReplies: 5Last Post: 11-16-2010, 07:40 AM -
Passenger side front running/blinker lights exploding
By rolyan76 in forum General HelpReplies: 1Last Post: 04-16-2007, 06:14 PM -
front driver side head light wont go down
By 1959ls1 in forum Almost Anything GoesReplies: 5Last Post: 07-26-2006, 09:39 AM -
WTB: Driver's Side Front Fender -'94 Camaro
By '99 SLP#24 in forum Parts Wanted / TradeReplies: 4Last Post: 03-11-2006, 09:27 PM
