    Member barryz's Avatar
    roosendaal , netherlands
    2000 transam ram air WS6
    Driver Side blinker doesnt work
    Hey guys
    Changed engine etc everything back together
    Hazourd lights flash day time running lights work turning signal
    Drivers side das does not blink stays on same Colour green constant
    Anybody has any ideas or a electrical drawing from the car 2000
    Trans am ram air ws6 also back up light does not work
    Let me know thank you
    Barry
    Check your bulbs the rear. If it goes out it also effects the front.
    Can there not a relais be broke?
    Or one wire connected wrong?
    Thanks
    It's possible there are 3 wires on the drl.
    In the pic below from left to right.
    F is for the flasher, D is the daylight running lights, and G is ground
    If the f and D wires are hooked up wrong they will stay on.
    Front is not the problem does any one have a picture how the drivers Side rear had to Be connected just to check everything thanks
    I'll look to se if I have a pic
    Thanks in advence
    Nobody?
  1. HELP! right turn signal doesnt work! (2000 WS.6)
    By ScottWernWS6 in forum General Help
    Last Post: 12-01-2010, 06:07 AM
  2. Radio doesnt work but CD player does....
    By cujo in forum Stereo and Electronics
    Last Post: 11-15-2009, 09:58 AM
  3. Internet explorer doesnt work on my laptop
    By 310stanger in forum Computers / Gaming
    Last Post: 10-26-2009, 11:57 AM
  4. Front driver side blinker
    By Mr. Luos in forum General Help
    Last Post: 04-08-2007, 08:54 AM
  5. key fob doesnt work!!
    By camd98z in forum Stereo and Electronics
    Last Post: 08-09-2006, 10:28 AM
