    White Plains, NY
    2002 Trans AM
    Junior Member bloop's Avatar
    Ohio
    Maple Red Metalic
    2000 Trans Am
    It is fake. There is a system used in some areas that will change lights, but it has nothing to do with universal remotes. Why would a remote company include this anyway. They have enough stuff to pack into a remote that is used by their customers. If you want lights to change for you, become a firefighter then promote to driver and make sure your community has one of these systems. It should only take a couple years.
    Impounded 86 IROC-Z's Avatar
    Everything fiberglass
    2005 Amberlamps
    Apparently some places have sensors that pick up a strobe light thats mounted on the front of some emergency vehicles... and they say if you flash your high beams it could change it
    2005 Amberlamps
    that video did look fake though
    2005 Amberlamps
    Heres what I was talking about...
    Item No.: MIRTTCD
    List Price: $599.00
    Our Price: $299.00
    You Save: $300.00
    Shipping Weight: 5.00 pounds
    Quantity: Add to Wish List
    Item Description
    PORTABLE
    CHANGE STOPLIGHTS FROM RED TO GREEN IN SECONDS! For the first time, a traffic light changer that is practical, mobile, AND compact! "MIRT" can be securely positioned on the dash or inside windshield and moved from vehicle to vehicle with no installation required. Just plug it in and go! Its unique infrared technology emits no visible light, making it discrete and eliminating any distraction to the driver or other vehicles in the vicinity.
    POWERFUL
    Do not be fooled by MIRT's compact size. Emitting 15 watts of energy (more than any other portable traffic light changer) MIRT changes traffic lights from red to green in 2 to 3 seconds from more than 1500 ft.
    RELIABLE
    MIRT is manufactured by a trusted name in the industry with more than 15 years experience. All electronic components and assembly are top quality, and every unit is tested to ensure endurance, dependability, and safety. It is perfect for the heavy duty use and is backed by a 10-yr. warranty!
    ECONOMICAL
    The technology of MIRT is not only "breakthrough", it is by far the most price-efficient signal changer available...costing less than half of any competing product. Check out the order page for the amazing pricing details or go to our HOME PAGE to see MIRT in action!
    Volunteer 1st Responders, Private Investigators, Emergency Volunteers, City & State Highway Workers, Security Personnel, Community Services, Fire Fighters, Mass Transit, Doctors, Police, EMS
    Explanation of Traffic Signal Preemption
    The normal operation of any traffic signal controlled intersection is designed for the maximum and efficient throughput of vehicular traffic.
    Unfortunately, a common occurrence at any intersection is traffic back-up, which can require many signaling cycles to clear. Without the ability to change the operation of the traffic signals themselves, police and emergency response vehicles can also be forced to sit in traffic, thus dramatically increasing their response times to crime scenes and fire or medical emergencies.
    Furthermore, even without heavy traffic, a police or emergency response vehicle entering a traffic signal controlled intersection at a high rate of speed places all motorists (and sometimes pedestrians) at extreme risk.
    Traffic signal preemption is an optical communications system that allows preemption-equipped vehicles to alter the normal operation of preemption-equipped traffic signals.
    An overview of a typical scenario is as follows:
    A fire truck is dispatched to an emergency.
    The fire truck is equipped with multiple emergency warning lights and a siren… The fire truck is also equipped with a preemption transmitter, which, in operation, is a high intensity forward-facing strobe light that is flashing at a rapid rate - much faster than normal attention-getting lights on the fire truck.
    When the fire truck approaches within 1,800 feet (line-of-sight) of a preemption-equipped traffic signal controlled intersection, the preemption detector (normally mounted on the cross-arm that suspends the traffic signal) "sees" the fire truck’s preemption transmitter and locks onto its flashing strobe.
    Once the traffic signal "sees" the fire truck, it begins to initiate a "preemption sequence" of the actual traffic signal that is different from normal operation.
    If the fire truck already has a green light, the light will remain green. Any other direction that also has a green light (usually the opposite direction) will first get a yellow light, then red.
    When all of the other directions are then red, and the fire truck’s direction is the only one that is green, the left turn arrow will illuminate (if one exists), and a brilliant white flood lamp mounted near the traffic signal will begin to flash. This flood lamp tells the driver of the fire truck that he now has control of the intersection, and complete right-of-way.
    If the fire truck has a red light, any other direction that has a green light will transition to yellow, then red. When all the directions (including the fire truck’s) are red, the traffic signal facing the fire truck will then turn green, along with the left turn arrow (if one exists), and the brilliant white flood lamp will begin to flash.
    Once the fire truck has passed through the intersection, optical communication with the preemption detector (on the traffic signal) is lost. At that time the traffic signal will default back to normal operation. Conversely, until the fire truck passes through the intersection, it will have a green light, regardless of the time duration.
    If several intersections are within the 1,800 foot range of the fire truck’s preemption transmitter, they will all respond accordingly to the above operational description.
    http://www.affordableaccessories.com...&where=catalog
    http://www.themirt.com/stealth_how.html
  1. Fake or Real.?
    Last Post: 06-17-2014, 03:43 PM
  2. are these real slp tips or real fake
    By z28_81 in forum Appearance Section
    Last Post: 11-27-2008, 02:19 PM
  3. BIG FOOT real or fake ?????
    By bealschad in forum Almost Anything Goes
    Last Post: 08-17-2008, 07:33 PM
  4. Are these real or really fake?
    By 02ultraZ in forum Camaro / SS
    Last Post: 06-29-2007, 08:05 AM
  5. real boobs or fake boobs
    By F-Bomb in forum Almost Anything Goes
    Last Post: 01-04-2007, 12:24 AM
