Results 1 to 20 of 23
Thread: The tune helped.....
04-04-2007, 02:41 PM #1BAHHBYE
- Jun 2006
- Gonzales, La
06 PBM GTO(458WHP)SOLD!!- 06 TR GTO~476WHP 425TRQ
Well i found a run after getting my A/F ratio corrected.....and it was a exhaust only 2001 Zo6. From a 20 roll (both spun but he spun worse) and i had him by 2+ by 125. Then from a 60 roll we both hooked and i had him by about 1 car tilll 125......he turned around and i gave him a thumbs up and he just looked at me all pissed off and shit....well at least now i know my car with it running right should trap about 114+ and i finally got to run a almost stock Z06.....cause b4 the tune i woulda been disappointed..lol
BTW "BLKCLOUD" you can make all the irrational statements you want buddy
04-04-2007, 03:22 PM #2
04-04-2007, 03:26 PM #3
04-04-2007, 03:31 PM #4
dam kid, whats done to your car again?
04-04-2007, 03:47 PM #5BAHHBYE
- Jun 2006
- Gonzales, La
Fully bolted.......Stage 2,CCA Front Mount,Turbo XS RFL Blow Off Valve,Needswings Downpipe with E-Cutout, TWM STS,Prothane MM inserts, AGP Race Gear Selector,Eibach Pro-Kit Springs,ED hardpipes & o2 housing,MSD wires,MPX 62mm TB,NGK iridiums, AGP Race wastegate, AEM wideband, PTP MAP Clamp.
Untuned it went 13.2@109 "8" passes hotlapping in mild weather with high humidity. Now i dunno what its gunna do...
04-04-2007, 03:55 PM #6
on paper, I don't see how you'd be able to pull a Z06 that hard. Even if your tune got you into the high 12's a Z06 can do that stock. From my own personal experience I've only seen SRT-4's fall off as the speed increased, but then again I've only raced a few and I doubt they were modded to the extent your is.
04-04-2007, 04:06 PM #7
i believe you but agree with the above
especially from a 60 roll, u know these cars are highway monsters
04-04-2007, 05:27 PM #8
Sounds fishy.
Either way, I wish I can get my car tuned.
99 T/A M6
LS6 intake, Hooker Coated Long Tubes, Y-pipe w/1 carsound cat, Hooker Catback, MTi Clear Lid, FRA w/ Holley Power Shot, ASP crank pulley, 1.8 RRs, 3.73s w/TA girdle & Eaton Differential, Granatelli SFCs, Pro 5.0 Shifter, LS6 Clutch, Diablo, TByrnes Maf Ends (in winter), All the Free Mods
04-04-2007, 06:39 PM #9Member
- Nov 2006
- louisiana
- 2002 transam ws6
I'll have to back Stone on this one. I've seen his car and know it is capable of doing what he did. Like he stated before around the baton rouge area we have a lot od badass cars riding around. There are a lot of highly modded cars here. His car is a beast. Good run Stone. It seems you run into a lot of races around here with good cars. I can't get anybody to run riding around here.
04-04-2007, 06:39 PM #10BAHHBYE
- Jun 2006
- Gonzales, La
Well i can assure you it happened.....whether or not it was driver or whatever i dont know. But going from a roll you dont really go by track times........my high 13 is equal to a mid to low 12 second pass.....but if my car traps 113+ than i beleive it was a legit run.....but like i said my car im sure picked up 25+ hp at the wheels, which would equal in my car to at least 3-4 mph.
04-04-2007, 06:43 PM #11
04-05-2007, 04:48 AM #12
1 car from 60-125 is plausible. all that means is both cars are pretty much the same ET wise. stone got the pull is all.
04-05-2007, 06:05 AM #13
wow, I am going to go ahead and do it. Are you sure it was a z06?
could have just had the rims?
04-05-2007, 07:27 AM #14Member
- Jul 2006
- oceanside ca
Red- 06 GTO
i believe you stone, srt-4's are more of a freeway car than a track car. They pull really strong up top. GOOD KILL
97 t/a
Magnaflow catback, K&N FIPK, chrome 17x9.5 zr1's, 3.42 gears, full pioneer sound system
cavpat; 100 the first race, he wanted to go AGAIN for another $100? LMFAO
What do you tell a ricer that's out $200?
...Nothin, you done told him twice! LOL
04-05-2007, 10:27 AM #15
04-05-2007, 02:48 PM #16BAHHBYE
- Jun 2006
- Gonzales, La
The car had Dark Grey Zo6 wheels and badging in the right spots on both sides....so im pretty sure it was. Yea we prolly are close MPH wise but he should have me e.t. wise if he can drive at teh track..........BUT no more racing for me for a while b/c i found my oil leak........and its a main seal.......and its getting worse
04-05-2007, 03:13 PM #17
good run it sucks to hear about your main seal
04-05-2007, 03:19 PM #18
04-05-2007, 03:25 PM #19
04-05-2007, 03:32 PM #20
Thanks: everyone who helped me pick out my tint!
By Mr. Bobo in forum Firebird / WS6Replies: 39Last Post: 07-31-2008, 07:57 PM -
Check it out, Helped a Friend make some Ricy V-Dub
By Rikki_SeVeN in forum Almost Anything GoesReplies: 2Last Post: 11-14-2007, 04:48 AM -
Belt condontioner/greaser helped..a lil what now?
By bgable in forum General HelpReplies: 4Last Post: 07-30-2007, 08:33 PM -
What are some quotes/sayings that describe you and have helped you through life?
By Ice Spiral in forum Almost Anything GoesReplies: 43Last Post: 03-09-2006, 05:19 PM
I wish i had about 5k laying in the bank cause it would be gone!!
