04-02-2007, 04:35 PM #1
getting new tires what size should i go with
whats up everyone, i have a 2004 gto and its time for some new tires. im planning on getting 275/40-17 in the back and leaving the stock size in the front. i heard alot of ppl say you get alot of tire rub with the 275 in the back is there anyone out there that has this size of tire and is happy with it? would realy apriciate any info
thanx,
1fastgto
04-02-2007, 06:21 PM #2
It depends on whos 275/40/17 you buy. There might need to be some quater lip grinding to do......
Nothing to major!!
I would put 245/45/17 on the front and 275/40/17 on the rear. That will give it a nice stagger and the heigth is the same.
Tire brand all depends on what you want to do with the car and if your budget limited.Don't be afraid of the bottle!!! Be afraid of your tune!!!
04-02-2007, 06:52 PM #3
well the car is a dd and i do take it to the track so i need something that will hook good but get @ least 10000 miles out of. somethins soft but not too soft
04-02-2007, 09:02 PM #4
04-03-2007, 09:25 AM #5
If your NOT limited on your budget I'd get the Pilot Sports.
I've gone 11.0's on there 20's @ 130mph.
Yes they are expensive but theyu do work and ride great. Thats why MOST "super cars" come with them stock.
04-05-2007, 10:22 AM #6
HI LS2Tuner, and what if you are limited on budget. What do you recommend. I've heard the NITTO's run a little narrower than most. What do you think. I've also heard people getting 10000 out of the DR's. ??? I'm also looking for some new tires. I don't drive it much, not in bad weather (unless I get caught), and pretty much in a straight line, and I drag race it so I am looking for a DR I can drive on the street also. I don't want to be changing tires at the track. I'm not in good health and changing the tires in the heat is just to much for me. I'm thinking about the Nitto's. I know the MT DR's work better at the track, but I think they are wider and require the finders to be rolled/cut. I would rather not do that if I can get away without it. 1fastgto, I don't want to high-jack your post, but I think the info will help both of us. Thanks Gunny
04-05-2007, 10:49 AM #7
I would go with the KumhoSupra 712's for the front and run a BFG DR on the rear. The section width is with in a 1/8" between the Nittos and the BFG's. The BF's hook better on the street and the track. We only saw about a 100-200 mile window of difference in life also.
04-06-2007, 11:27 AM #8
get the 275's and just grind the lip down a lil like i did....my goats dropped and i still only cut the lip half as much as i wanted and it rubs only time to time now
01 m6 z28 - lid / lt headers / 3' ory w no cats / flowmaster catback w 3' dmh e-cutout / nelson pcm tune
04-06-2007, 12:56 PM #9
Get the 275's. Which tire?
2004 GTO, A4, Torrid Red/Blk, 1 of 1031, Yank SS3600, Dart-225s 62cc, Cometic .040, CompCams 230/236-.613/.608-112LSA, Hi Tech 7.350 pushrods, Kook 1 7/8, CAT/Reson. delete, 3" H-pipe, super 40s, Ported TB, TB bypass, 160TS, SLP MAF, JBA wires, NGK TR-55, New ERA CAI, tuned = 392hp/344tq
04-06-2007, 06:18 PM #10
Very few brand will fit with rubbing unless you use the Pedders 5/16 springs or drag bags. And even with that you may need to roll or grind your fenders.
10.954 123.58 1.496 489.29 rwhp 475.52 rwtq
04-08-2007, 02:57 PM #11
I have a set of MT ET Streets, 26 x 11.5 x 17. I had them on my stock rims, and I never had a rub. They are over 12" on the outside. Are 275's wider than that? Is it normal for that size of tire to not rub? I haven't done any bending or cutting. My car is almost done, so I have to get going and order some tires. Thanks, Gunny
04-08-2007, 03:29 PM #12
What size of tires please
By stefos in forum Wheels and TiresReplies: 9Last Post: 05-16-2010, 03:28 AM -
What size tires won't rub
By 2001camaroSS in forum Wheels and TiresReplies: 31Last Post: 02-21-2010, 09:03 PM -
what size tires can I fit under my SS?
By SmokinSS in forum Wheels and TiresReplies: 3Last Post: 01-29-2010, 10:55 AM -
what size of 18's tires
By stefos in forum Wheels and TiresReplies: 3Last Post: 03-18-2009, 10:51 PM -
What Tires Size
By B.A.N.A.T.A. in forum Wheels and TiresReplies: 2Last Post: 08-25-2008, 08:12 AM
i still have my factory bfgoodrich tires on it
