Results 1 to 20 of 32
Thread: What size tires won't rub
02-16-2010, 09:41 AM #1Senior Member
- Feb 2010
- Greenwood, IN
Light Pewter Metallic- 2001 Camaro SS
I've lowered my SS with the Eibach prokit which lowers the car 1.5" front and 1.3" rear. I'm about to purchase some wheels that are 18x9.5 front and 18x10.5 rear and was going to get 18/35/275 front and 18/35/295 rear. Is this going to be a problem?
2012 Regal GS
2004 Cadillac CTS-V (Sold)
2001 Camaro SS (Sold)
1999 Camaro Z28 (Sold)
02-16-2010, 10:34 AM #2
thats what im running an dont have a problem but if i went much wider on tires id have to do the BFH mod
02-16-2010, 12:00 PM #3Senior Member
- Feb 2010
- Greenwood, IN
are u using a spacer or anything?
02-16-2010, 02:08 PM #4
With the correct offset(+50 to +44) rubbing should not be an issue on a 10.5" wheel, even with 315's.
So what's the offset on those wheels?Last edited by Blue28; 02-16-2010 at 02:10 PM.
02-16-2010, 04:21 PM #5Senior Member
- Feb 2010
- Greenwood, IN
I believe the fronts are 54mm and the 10.5's are 56mm
02-16-2010, 05:21 PM #6
You'll be fine up front, but in the rear BFH mod, and/or 5/16" spacers and ARP wheel studs.
02-16-2010, 05:32 PM #7
02-16-2010, 05:41 PM #8
BFH = Big Fucking Hammer, in my town any way. lol ARP is just a bolt manufacturer.
02-16-2010, 07:58 PM #9
02-17-2010, 11:13 AM #10
i have 275 on my 10.5 an i didnt have to do anything but if i went bigger i would have to
02-17-2010, 12:18 PM #11
02-17-2010, 07:07 PM #12
02-19-2010, 02:20 AM #13
im not sure ill look tomorrow to cold to go check right now
an i think my off set is 54mm not sure ill check that to
02-21-2010, 09:01 AM #14Crazy Canuck !
- Jun 2002
- Montreal, CANADA
if your wheel is a 18x10.5 +56mm, get a 1/4" spacer and be done w/ it.
That's what I have on my car... pix in signature links.
And 315/30-18 (stock overall diameter) will fit better than your 295/35-18 that are taller and more prone to rubEugenio_SS
02-21-2010, 10:30 AM #15
02-21-2010, 11:21 AM #16Crazy Canuck !
- Jun 2002
- Montreal, CANADA
it's not that low.
remember that 30 means it's 30%
because the tire is wide, you still have plenty of sidewall.
It's the exact same sidewall as 275/35-18
Here are 2 pix w/ the 315/30-18:
02-21-2010, 02:02 PM #17
02-21-2010, 06:29 PM #18
i am in the same exact boat and am a little hesitant to purchase the 315's. im not so much worried about the fender well as i am the fender lip. i dont want to have to roll it. my rim size and offset will be the same as mentioned before, 18x10.5 and 56mm. and im lowered on the pro kit too.
02-21-2010, 07:02 PM #19
02-21-2010, 07:10 PM #20
i really want the 315's, but like i said do not want to roll the fender. the bfh mod wont bother me. so im not sure yet
What size of tires please
By stefos in forum Wheels and TiresReplies: 9Last Post: 05-16-2010, 03:28 AM -
what size tires can I fit under my SS?
By SmokinSS in forum Wheels and TiresReplies: 3Last Post: 01-29-2010, 10:55 AM -
what size of 18's tires
By stefos in forum Wheels and TiresReplies: 3Last Post: 03-18-2009, 10:51 PM -
What Tires Size
By B.A.N.A.T.A. in forum Wheels and TiresReplies: 2Last Post: 08-25-2008, 08:12 AM -
getting new tires what size should i go with
By 1fastgto in forum GTOReplies: 11Last Post: 04-08-2007, 03:29 PM
