Results 1 to 1 of 1
10-12-2005, 05:05 PM #1dropt98chevyGuest
FS: NEC LCD2010T Touchscreen Monitor
This monitor retails for $2500 but the one I have is a refurbished model but everything has been replaced except for the casing itself. I would like to get $1000 for this but will consider other offers. I have not even pulled it out of its box yet. So since the refurb it has NEVER been used. My truck had a boot put on it today which cost me $445 to get off and I had to borrow all the money from friends so I am trying to get rid of this so I can pay them back.
The MultiSync LCD 2010T (20.1" viewable image size) monitor offers MicroTouch® capacitive touch technology. MicroTouch is the leading provider of touch technology in the world. The MultiSync LCD 2010T monitor is the world's largest touchscreen LCD. The MultiSync LCD2010T touchscreen monitor is well-suited for a wide array of applications utilizing touchscreen interface such as financial, industrial, medical, hospitality industry, Information and interactive kiosks, and Retail Point-of-Sale. NEC's exclusive XtraView® wide viewing angle technology and the portrait/landscape capabilities makes the NEC MultiSync 2010T LCD monitor the most advanced touchscreen on the market today.
Detailed Specifications:
Active Display Area:
Landscape:
Horizontal: 15.7 inches / 399 mm
Vertical: 12.6 inches / 319 mm
Portrait:
Horizontal: 12.6 inches / 319 mm
Vertical: 15.7 inches / 399 mm
(Dependent upon signal timing used)
Current Rating:
1.0A @ 100 - 120V / 0.5A @ 220 - 240V
Dimensions:
Net Landscape:
19.6 in (W) x 19.7 in (H) x 10.3 in (D)
498 mm (W) x 501 mm (H) x 262 mm (D)
Net Portrait:
16.5 in (W) x 21.3 in (H) x 10.3 in (D)
418 mm (W) x 541 mm (H) x 262 mm (D)
Height Adjustment: 3.1 in / 80 mm
Gross:
26.1 in (W) x 27.2 in (H) x 16.2 in (D)
662 mm (W) x 691 mm (H) x 412 mm (D)
Display Colors:
Analog Input: Unlimited Colors
(Dependent upon display card used)
Input Video Signal:
ANALOG 0.7 Vp-p/75 Ohms Positive
LCD Module:
20.1-inch (20.1" viewable image size), active matrix,
thin film transistor(TFT), liquid crystal display
(LCD), 0.31 mm dot pitch, XtraView technology, RGB
vertical stripe color filter arrangement, 105 cd/m2
white luminance typical, 150:1 contrast ratio - typical
Operating Altitude:
0 to 10,000 Feet
Operating Humidity Range:
30% to 80%
Operating Temperature:
+41° F to +86° F / +5° C to +30° C
Power Management:
IPMâ„¢ (Intelligent Power Manager) System,
EPA Energy Star, meets NUTEK based on
2 power saving modes
Power Supply:
AC 100 - 240V worldwide input @ 50/60 Hz
Recommended Resolution:
Landscape: 1280 x 1024 @ 60 Hz
Portrait: 1024 x 1280 @ 60 Hz
Regulatory Approvals:
UL 1950, C-UL, FCC Class B, Canadian DOC, CE,
TUV/GS, TUV/ISO9241-3/8, MPRII, C-tick
Resolutions Supported:
Landscape:
720 x 400: VGA text
640 x 480 @ 60 Hz to 76 Hz
800 x 600* @ 56 Hz to 76 Hz
832 x 624* @ 75 Hz
1024 x 768* @ 60 Hz to 76 Hz
1280 x 960 @ 60 Hz to 76 Hz
1280 x 1024 @ 60 Hz to 76 Hz
Portrait:
480 x 640 @ 60 Hz to 76 Hz
600 x 800* @ 56 Hz to 76 Hz
624 x 832* @ 75 Hz
768 x 1024* @ 60 Hz to 76 Hz
960 x 1280 @ 60 Hz to 76 Hz
1024 x 1280 @ 60 Hz to 76 Hz
*Due to the interpolation necessary for
operation of LCD panel resolutions at
full screen, it is recommended that LCD
monitors utilize the full resolution
capability of the panel and are operated
at their optimal or maximum resolution
when text or fine lines are being viewed.
NOTE: Some systems may not support all modes listed.
Signal Cable:
15-pin mini D-SUB male to 5-branched BNC male
Storage Altitude:
0 to 45,000 Feet
Storage Humidity Range:
10% to 85%
Storage Temperature:
+14° F to +140° F / -10° C to +60° C
Sync:
Seperate sync: TTL Level
Horizontal sync: Positve/Negative
Vertical sync: Positive/Negative
Composite sync: TTL Level, Positive/Negative
Sync on Green: Video 0.3 Vp-p Negative
Synchronization Range (Automatic):
Horizontal: 24.0 kHz to 80.0 kHz
Vertical: 56.0 Hz to 76.0 Hz
User Controls:
Power, Brightness, Contrast, Vertical
and Horizontal Position, Auto Adjust,
Image Adjust, AccuColor® Control System,
OSMâ„¢ Lock Out, OSM Horizontal Position,
All Reset, Horizontal Size, Fine
Weight:
Net: 30.9 lb / 14.0 kg
Gross: 41.9 lb / 19.0 kg
Touchscreen unit for T/A?
By Clint in forum Stereo and ElectronicsReplies: 6Last Post: 05-19-2009, 01:06 AM -
finished the bezel for my touchscreen.
By ls1bandit in forum Stereo and ElectronicsReplies: 7Last Post: 06-13-2008, 08:03 AM -
Question: In Dash Touchscreen with the bird on the screen!!?
By RaptorHawk in forum Firebird / WS6Replies: 12Last Post: 05-29-2008, 10:40 PM -
is there a way to monitor NX on a 7" monitor?
By greatwhiteZ28 in forum NitrousReplies: 7Last Post: 08-22-2007, 06:00 PM -
NEW touchscreen in-dash dvd player
By camaross2000 in forum General ClassifiedsReplies: 5Last Post: 05-28-2007, 09:34 AM
