    d
    2002 z28
    is there a way to monitor NX on a 7" monitor?
    well go this idea from fast and furiouis and have a 7" monitor screen laying around and would like to know how big of a deal it is to make it fucntion with my NX
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    well, you need software to be able to read the PCM.
    d
    2002 z28
    lots of extra $$$ i guess
    Member tyxpx's Avatar
    Florida
    Impulse Blue
    2006 GTO
    That would be pretty cool. I wanna know about this also.
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    Get a NX Maximizer hook it up to a PDA that has a output for external monitor and hook that to your 7"..........
    d
    2002 z28
    thanks, how much is the maximeizer and is it worth it? the monitor is really just laying around and would like to see some use out of it
    Aug 2006
    WestCoast AZ-CALI
    05 Goat SMASHED
    You can find one for around $800.Yes it's worth it it's the best progressive controller that I know of read the features.
    I tune it to watch a small window in the 02's so the milisecond it starts to go lean it stops the nitrous flow. I can go on and on about the features forever here is a description......... I have the Mazimizer I for my own cars.
    The "Next Generation" NX Maximizer 2 is finally here! This state of the art digital nitrous controller delivers the performance that nitrous users have dreamed about. Check out the capabilities and features that make this nitrous controller the new standard in digital nitrous power management.
    ·Dual Stage independent output channels (independent profiles for each channel)
    ·Time-based ramped delivery of nitrous and fuel (unique programmable delay and ramp times for up to 8 gears)
    ·RPM-based delivery of nitrous and fuel (unique programmable curve for up to 8 gears)
    ·Throttle-based modifier of nitrous and fuel (reduce nitrous delivery by up to 35% based on throttle position)
    ·LEAN threshold automatic “cut-off ” when using FJO Wideband system
    ·Programmable RPM trigger point and cutoff
    ·Programmable MAP cutoff (when using nitrous as an "anti-lag" system)
    ·Nitrous pressure sensor input
    ·Built-in MAP sensor reads from vacuum to 48 psi of boost
    ·Gear detection for manual and automatic transmissions
    ·Inputs for arming switch, bottle heater enable switch, 2 trigger switches, throttle position, tach signal, nitrous pressure, and Air/Fuel Ratio (narrow or wideband)
    ·2 configurable outputs for either: integrated bottle heater control, integrated bottle opener control, automatic N2O purge function, or status LED
    ·2 ignition retard outputs
    ·Digital communication port for PC or digital gauges
    ·Easy to use graphic set-up menus and datalogging using Windows™-based PC
    ·High current 2-channel solenoid driver
    *Standard discounts do not apply to SPEED products.
    d
    2002 z28
    wooow thanks alot, looks lilke that is something worth it to do for that screen that i have laying around,
    thanks again
  1. For Sale: Samsung 22" widescreen monitor & desktop PC
    By Never-Enough in forum General Classifieds
    Last Post: 06-26-2011, 02:09 PM
  2. new monitor on the way...
    By 0rion in forum Computers / Gaming
    Last Post: 01-07-2011, 07:47 AM
  3. Just got a 22" HD LCD computer monitor from.....
    Last Post: 02-09-2009, 02:42 PM
  4. Selling Dell 18" monitor
    By uLs1a in forum Western Members
    Last Post: 01-07-2009, 08:58 PM
  5. For Sale: Samsung 17" LCD HDTV/Comp.Monitor CHEAP
    By TooFastT/A in forum General Classifieds
    Last Post: 05-15-2008, 04:48 PM
