Thread: STock Valve Springs
03-26-2007, 11:18 AM #1
STock Valve Springs
Is it a must to change the valve springs when putting in a bigger cam then stock? Say around .580 lift?
Also, is 110 a tight LSA on an LS1?
Thanks,
Chris
03-26-2007, 05:35 PM #2
Yes, you def need new, stronger valve springs.
And 110 is a really close LSA for an N/A motor. If your running a power adder, then it should be fine, depending on your application.
03-27-2007, 05:23 AM #3
- Dec 2002
- n/w chicago
new spring retainers and hardened pushrods
a few bolt ons, 379 rwhp
11.96 @113.25
03-27-2007, 08:25 AM #4
Thanks guys. As far as the LSA goes, what would teh charecteristics be? I would ASSuMe a pretty radical idle, but would it still be streetable, for a semi-daily car? I'm used to a 108 LSA in my BB Chevelle, so would it be much different then that cam's charecteristics?
Chris
03-27-2007, 10:54 AM #5
You might have vacuum troubles with a 110. Some people run an NA 110 LSA, but I don't remember if they needed a vacuum pump too.
03-27-2007, 02:52 PM #6
No doubt about it. Besides, you may also want to check the clearance between your retainer and valve guide/seal.
03-27-2007, 03:45 PM #7
Thanks guys. I appreciate the help. I just have one more question, but it's in regards to the valve springs. How much lift can stock LS6 springs handle?
Chris
Are the stock Ls1 valve springs weak?
By importssuck in forum Internal EngineReplies: 5Last Post: 05-03-2012, 05:14 PM -
Stock LS1 Valve Springs...
By OnEbAdReDSS in forum Internal EngineReplies: 13Last Post: 08-08-2008, 01:17 PM -
New valve springs w/stock cam question
By rel3rd in forum Internal EngineReplies: 3Last Post: 08-15-2007, 12:56 PM -
IL: stock 2002 LS1 cam and valve springs
By shaitiger in forum Parts For Sale / TradeReplies: 3Last Post: 08-15-2006, 07:39 AM -
Stock valve springs?
By rnl35thss in forum Internal EngineReplies: 4Last Post: 02-15-2006, 06:15 PM
