05-01-2012, 03:26 PM #1
Are the stock Ls1 valve springs weak?
In stock form are the stock LS1 valve springs weak? Are thy known to break?
05-01-2012, 05:30 PM #2
- Jun 2011
- Branchville, NJ
Not that I know of. I do not know the pressure they hold but I have not heard about a mass failure in those springs.
05-01-2012, 07:24 PM #3
on the stock cam they should last a good long while.......if you're asking because you want to use them with an aftermarket cam then they're a terrible option. Nothing past stock lift.
05-03-2012, 09:17 AM #4
- Aug 2011
- Browns Mills NJ
Green- 1995 Z28 w/ LS1 Swap
Stock setup there fine...
Heads/Cam/Intake/Stall.
404 Rwhp uncorrected @ 6400
05-03-2012, 11:16 AM #5
They'll work if left alone, but yes they are somewhat weak. I've heard instances on low mile examples to only have as little as 60 lbs. seat pressure.
It's also why they seem to like to bend pushrods when bounced off the rev limiter, the stock springs have terrible valve control at those rpms.
05-03-2012, 05:14 PM #6
- Aug 2010
- Oklahoma City, Oklahoma
sebring silver- Y2K SS CAMARO
they work just fine on the stock cam but HAVE to be upgraded if you install a bigger cam, might as well do retainers and locks while your in there too
2000 ss camaro, forged lq9 370 short block, stage 3 PRC 243 heads, fast 102 w, big mouth throttle body, MS3 cam, 1.7 roller rockers, stage 3 t-56, monster stage 3, pro 5.0, 4.10's with moser axles, bmr tq arm, lca's, phb. SOLD (thankfully)!!!
New project: 1968 step-side, partial restore, ls/th400 swap. hopefully boosted pics and more info to come!!!
Having a small cam is like having a small dick, everytime you go to use it you wish it was bigger
Stock LS1 Valve Springs...
By OnEbAdReDSS in forum Internal EngineReplies: 13Last Post: 08-08-2008, 01:17 PM -
New valve springs w/stock cam question
By rel3rd in forum Internal EngineReplies: 3Last Post: 08-15-2007, 12:56 PM -
STock Valve Springs
By redss454 in forum Internal EngineReplies: 6Last Post: 03-27-2007, 03:45 PM -
IL: stock 2002 LS1 cam and valve springs
By shaitiger in forum Parts For Sale / TradeReplies: 3Last Post: 08-15-2006, 07:39 AM -
Stock valve springs?
By rnl35thss in forum Internal EngineReplies: 4Last Post: 02-15-2006, 06:15 PM
