Thread: push rod diameter
03-24-2007, 10:35 AM #1
push rod diameter
anyone know the dia. of the push rods for a 98 z-28 ls1. 5/16 or 3/8?
please help!!!!
03-25-2007, 06:22 AM #2
Believe the stock ones are 5/16. I questioned whether or not to go with the 3/8 ones when I did my heads and cam in my first T/A. I was told the 5/16 ones are better because of the less weight and the extra strength is not needed until you have a LOT of mods. My $0.02.
03-27-2007, 02:57 PM #3
I used to always go with the smaller pushrods to save weight but for high RPM applications (6000 and up) I usually go with 3/8 if I can because there is a lot of deflection in the smaller pushrods; even on the heavy wall versions. The extra weight is offset by the better stability and the fact that you are getting more of your valve lift back.
Chris Crossont
A.H.M. Performance
Baltimore, MD
03-27-2007, 08:06 PM #4
stock is 5/16.
Question: Diameter of Intake
By The Silver Goat in forum GTOReplies: 11Last Post: 07-29-2009, 05:37 AM -
Question: Exhaust system diameter
By The Silver Goat in forum GTOReplies: 1Last Post: 07-05-2009, 10:07 AM -
Overall Diameter Table
By Eugenio_SS in forum Wheels and TiresReplies: 0Last Post: 03-15-2008, 11:49 AM -
Tire Diameter And Abs???
By EXTNCT in forum Wheels and TiresReplies: 2Last Post: 08-15-2007, 07:04 PM -
header diameter?
By delinquent543 in forum External EngineReplies: 5Last Post: 11-27-2005, 09:02 PM
