    Member The Silver Goat's Avatar
    Dearborn Michigan
    Qucik Silver Metalic
    2004 GTO - M6
    Diameter of Intake
    The diameter of the TB intake is 78mm correct?
    Member GTO1_OHIO's Avatar
    Melbourne Beach, FL
    Phantom Black Metallic
    2004 GTO
    Quote Originally Posted by The Silver Goat View Post
    on a 04. yes.
    mercersburg pa
    hugger orange
    2004
    and the outer diameter is just right to use a thick rubber band for a gasket if you are making a cold air intake tube out of 4" PVC
    Melbourne Beach, FL
    2004 GTO
    I'm not sure I'd want to attach something that rigid directly to the TB.
    mercersburg pa
    hugger orange
    2004
    Quote Originally Posted by GTO1_OHIO View Post
    it actually works very nice. used a hard 90°, then goes into a rubber fernco fitting that gives plenty of flex before the rest of the tube. i
    used a regular hose clamp to hold everything tight
    Dearborn Michigan
    2004 GTO - M6
    Ironic you suggest that - I replacing my K & N sleeves. I'll look in it.
    Although I've got a web site in my favrites that offers all sorts of sleeves
    09 G8 GT
    is it possible to make a *somewhat* good intake with stuff from lowe's? and the 05-06 TB is 90mm correct?
    mercersburg pa
    hugger orange
    2004
    Quote Originally Posted by ls1fan74 View Post
    I did. get the thin wall 4" drain pipe, not scheduel 40.
    I used hard 90°, 2 45°, and a strait peice.....i cut a hole in the sheet metal uder where the old airbox sat.....fitted it all together and glued it so the new cone filter sits right behind the drivers fog light......then cut it after the 90° and put a rubber fernco fitting in to let it flex
    09 G8 GT
    Quote Originally Posted by mark21742 View Post
    sweet im gonna try that. Does it sound or perform any better, or both?
    mercersburg pa
    hugger orange
    2004
    $20 in parts from home depot+ a Specter filter from the auto parts store, and it works just as good as the $200 store bought piece.
    also I'm an SD tune so I have no MAF to worry about
    09 G8 GT
    I was re-reading this, and was thinking I wanna do it but also get a bigger throttle body as well. I saw Speed Inc sells an 85 and a 90 mm, are these bolt-on to a stock intake manifold?
    mercersburg pa
    hugger orange
    2004
    I know the 90mm's are 4 bolt and won't bolt up to an ls1 or ls6 mannifold, some of the 85mm's have both the 3 hole and the 4 hole pattern, but won't really give you any performace gains because the manny is still choked down to 78mm.
    I hate to say it, but best bet is to save up for a fast
  1. Overall Diameter Table
    By Eugenio_SS in forum Wheels and Tires
    Last Post: 03-15-2008, 11:49 AM
  2. HELP!!! need cutout diameter for stock car
    By First Spray777 in forum External Engine
    Last Post: 10-07-2007, 06:32 PM
  3. Tire Diameter And Abs???
    By EXTNCT in forum Wheels and Tires
    Last Post: 08-15-2007, 07:04 PM
  4. push rod diameter
    By ls1alltheway in forum Internal Engine
    Last Post: 03-27-2007, 08:06 PM
  5. header diameter?
    By delinquent543 in forum External Engine
    Last Post: 11-27-2005, 09:02 PM
