Thread: fuel pump booster
03-21-2007, 10:46 AM #1
fuel pump booster
installing sts turbo kit on 98 ls1 firebird. i have installed 42lb injectors. Do i need to run a fuel pump booster with sts turbo kit.msd said theirs wont work.
03-21-2007, 12:28 PM #2
Kenny bells BAP works great !
03-21-2007, 02:50 PM #3
kenny bells stuff looks great,and is a trusted name. How much was the BAP?
Do i need to run a BAP if i change to a 255 l/hr, or is it better to just boost the stock pump. Just about finished with the install, still have to put on Methanol kit,was hoping to get it on the dyno on Friday, But that is fast approching. Maybe we will shot for monday or tuesday. I already have the MSD(Part#2350) but i was told it will not work on the LS1's returnless system.
Do you know anything about it?
Thanks Alot in Advance
03-21-2007, 07:21 PM #4
The Kenny Bell is made to use on a returnless system, i used it , works great .
You can adjust the amount of power the stock pump sees from 13-20 volts, It comes with a 4psi hobbs switch, which means the kenny bell will send extra power to the pump at 4psi.
I paid $240 for mine
but worth it
03-23-2007, 12:08 PM #5
I used the MSD BAP before. Worked great before I upgraded the fuel system.
03-24-2007, 12:00 AM #6
They say it won't work but I have 2 customers that already had Boost a Pumps and I informed them MSD doesn't recommend them but they still wanted installed so I did and tuned. Both are still running with no fuel pump issues. One has been on the street for over a year now as a daily driver. The second one we added a return line and regulator a month ago.
Fuel pump fuel guage issues on my '02 B4C
By ANDYZ28 in forum Camaro / SSReplies: 7Last Post: 12-29-2014, 10:30 AM -
Pontiac Fuel Pumps - Do You Have The Right Fuel Pump?
By Ed Blown Vert in forum Firebird / WS6Replies: 0Last Post: 03-15-2011, 09:20 PM -
In-Line Booster Fuel Pump Question?
By Tman in forum Forced InductionReplies: 1Last Post: 10-16-2007, 10:23 AM -
msd fuel pump voltage booster
By 99transamC/FIA in forum Forced InductionReplies: 1Last Post: 03-25-2007, 08:40 AM -
Stock fuel pump/ how much fuel pressure can I run...
By jmangler in forum LT1Replies: 3Last Post: 10-02-2006, 06:23 PM
