Thread: noob question
03-18-2007, 06:45 PM #1
- Jan 2007
- STL,MO
noob question
noob questoin here because ive never had a automatic
i have a 3200 stall, at the track do i go to 1 and then shift to 2 and then drive?
03-18-2007, 11:21 PM #2
Just let the car do your shifting. It'll do it much better than you will. In other words, just put it in "D" for "drag race".
03-19-2007, 01:46 PM #3
03-19-2007, 03:54 PM #4
- Dec 2002
- n/w chicago
i leave my car in OD all the time. shifting down to 3rd makes no difference.
a few bolt ons, 379 rwhp
11.96 @113.25
03-20-2007, 05:29 AM #5
Orion, please make a sticky for these people, jusr drive you auto in D!!! there is no reason to shift manually other than maybe for burnouts, or if you just like to keep the revs high or engine break to hear that exahust.
And shifting from OD to D does make a difference, I imagine its not to good for the tranny though unless you slow down.
03-21-2007, 03:32 PM #6
- Jan 2007
- STL,MO
03-23-2007, 11:08 AM #7
- Mar 2007
- NC
NBM- 1998Z28
You have a 4L60E and the E stands for Electronic controlled. In other words when you start out in first and manually move the shifter to 2nd its not going to change to second until the CPU sends a signal to the tranny to change gears.Not even if you have a shift kit installed. And the CPU uses RPM and MPH info to determine that.Not the position of the gear shift lever.Leave it in OD unless you want to bang your rev limiter.
03-23-2007, 09:46 PM #8
This brings up something I noticed several years ago that I've seen discussed but never heard a good explanation of why. If you manually shift even if you just start in first and shift to 2nd immediately the shifts will hang a little longer. I know others have noticed this because I've seen it talked about before. Now I haven't manually shifted my car in many years but remember it doing this if I had it in 1 just playing around and punched it the 1-2 shift would be later than normal. I know the shift points, hell, I set them up in edit myself but I've never heard a good explanation as to why this happens.
Noob question on heads
By t5munoz in forum Internal EngineReplies: 10Last Post: 12-24-2010, 08:35 PM -
Noob Question... Pacesetter...
By 02B4CLS1 in forum External EngineReplies: 3Last Post: 10-02-2008, 10:11 AM -
Noob Question
By BlackLT1Z28 in forum DrivetrainReplies: 1Last Post: 02-28-2008, 11:30 AM -
Noob question
By BLKbandit98 in forum Wheels and TiresReplies: 6Last Post: 12-17-2007, 09:19 AM -
Noob cam question
By bwinch in forum Internal EngineReplies: 3Last Post: 05-13-2007, 07:09 AM
