Results 1 to 15 of 15
    US
    01 Formula
    boring a 5.3 to 5.7?
    I bought a 5.3 block and was told that they could be bored over to a 5.7. Now what is the final bore for the 5.3 to achieve the 5.7 aluminum bore?I need to know how much to tell the machine shop to bore it over.
    US
    01 Formula
    Anyone have any info?
    Aug 2006
    Missouri
    94 Camaro Z28
    Depends, what's the stroke?
    Senior Member mrr23's Avatar
    orlando, fl
    2014 camaro 2ss/rs
    you cannot bore the 5.3L (3.77 inches)out to the bore size for the 5.7L (3.898 inches).
    US
    01 Formula
    From what I was told it can be done.I think diffrence is .118 from 5.3 to 5.7.Stock stroke..
    orlando, fl
    2014 camaro 2ss/rs
    the only bores i've ever seen that could be bored past .060 is the old chevy big block motors. the 5.7L can only go .010" and the 6.0L can go .060". only one way to find out.....
    US
    01 Formula
    Yeah I also came across some ls1 type website I believe it was a truck site and in some of the customers cars it listed thier 5.3's bored to 5.7.
    Aug 2006
    Missouri
    94 Camaro Z28
    Maybe if you resleeved the block.
    nixa missouri
    63 chevy ll
    5.3 to 5.7 block
    you can bore a 5.3 to be 5.7 if you have a castiron block you can also bore a 4.8 to be a 5.7 but you have to use the 5.7 stroke crank your 5.3 bore right now is 96mm and your going to bore it to 99mm so yes it will work if you have a cast iron block if you have a aluminum 5.3 you will have to have inserts put in the block and that is very expensive good luck
    orlando, fl
    2014 camaro 2ss/rs
    well then, i have learned something new. man those will be some thin walls.
    Veteran Hi-Po's Avatar
    Florida
    1999 TA WS.6
    Holy smokes! What are your ultimate plans for this engine? I have never heard of anything taking that much from the bore. But that doesnt mean its not possible. But why? If it can be done, Your walls gotta be get'n scary thin, I would think. IMO, It doesnt sound economical.
    Gold Member BlwnCamaro's Avatar
    Las Cruces,NM
    1998 Z28 Camaro
    The 4.8 cast iron block and the 5.3 block can both be bored to 5.7. They call them the poor mans 5.7 cause you can get for cheap. They made the liners really thick on those blocks, and they share the same stroke as the 5.7's! Hope that helps you, I' ve got big plans for the local 4.8's and 5.3's in the wrecking yards!
    wisconsin
    Quote Originally Posted by BlwnCamaro View Post
    the 4.8's do not have the same stroke as the 5.3 and 5.7
    Ultimate nothing
    Fenton, MI
    2000 Trans Am
    Why not just pick up a 5.7 block? They are all over the place, save some weight and reliability. You are talking thining out the cylinder walls well beyond their service spec.
    Just because you CAN do something doesn't make it a good idea.
    I'm (Hurst) Equipped... davebowtie's Avatar
    Santa Barbara County,Ca.
    Onyx Black
    '02 Camaro SS(replica) M6
    overbore CAST IRON...
    overbore ALUMINIUM
    C:\Documents and Settings\Dave\Desktop\sig01.jpg
  1. Just another boring picture
    By MrMasterCraft in forum Camaro / SS
    Last Post: 04-26-2010, 05:13 PM
  2. Question: Boring .020 Over
    By BJDahlke in forum Internal Engine
    Last Post: 03-03-2009, 07:09 AM
  3. Question: TB Boring
    By mark21742 in forum Internal Engine
    Last Post: 02-24-2009, 02:33 AM
  4. Boring
    By Fearls1 in forum Firebird / WS6
    Last Post: 08-13-2008, 04:24 PM
  5. ls1.com getting a little boring?
    By Frankthetank in forum Almost Anything Goes
    Last Post: 03-20-2008, 10:42 PM
