Results 1 to 20 of 23
Thread: Just another boring picture
04-25-2010, 07:00 PM #1Senior Member
- Nov 2009
- NOVA
2002 C5 - M6 - Blue- 2000 Z28 - A4 - Pewter
So I cleaned it up, wasn't able to throw a coat of wax on it, still kind of waiting on getting my whole list together of the Zaino products I need to get started with, so I figured it wasn't worth it anyways. Here it is all cleaned up, took it in a hurry as I had to get goin' this evening to my mom's....
2000 Z - Light Pewter Metallic - A4 - 130k - Bolt Ons - My Pride and Joy
2002 C5 - Electron Blue - M6 - 32k - My Dream Car
04-25-2010, 07:04 PM #2Senior Member
- Oct 2008
- Coral Springs, Fl
looks good, always nice when its all clean
try cleaning up those headlights yet?
04-25-2010, 07:06 PM #3Senior Member
- Nov 2009
- NOVA
Maaaaaaan, I've used that Meguiar's "PlastX" stuff, it helped a tad but they're so far gone, I don't even know if it's worth buying anything else for 'em. Really thinking hard about getting some ebay lights, if I'm ever able to sell my wheels and get that rear I want
04-25-2010, 07:12 PM #4Senior Member
- Oct 2008
- Coral Springs, Fl
Try wetsanding them. If you start around 320 grit and work your way up to 2000 then polish they turn out pretty nice.
04-25-2010, 07:12 PM #5
They can be saved -- start by wet sanding them with 1000 grit paper and then buffing. Just don't apply much pressure with the buffer as you do not want to heat the lens up very much. My nephew does this for a local salvage yard as a sideline business. Takes a dozen or so lights at a time and makes them clear again.
The car looks great btw.
Someone beat me to the punch.Last edited by pajeff02; 04-25-2010 at 07:13 PM. Reason: I type too slow.
04-25-2010, 07:15 PM #6
04-25-2010, 07:17 PM #7Just me
- Nov 2006
- Broken Arrow, OK
Those headlights are not beyond saving. Wetsand them like mentioned.
04-25-2010, 07:18 PM #8
04-25-2010, 07:22 PM #9Senior Member
- Nov 2009
- NOVA
Interesting.... damn, I love how I just post up a picture and get some great informative advice!!! Those headlights have been bothering me ever since I got the car! I'll have to try the sanding on them this Saturday for sure!
Better start making my list...
04-25-2010, 07:22 PM #10
04-25-2010, 07:31 PM #11Senior Member
- Nov 2009
- NOVA
Quick question... Never been a body guy but I remember watching a show a few years back about wetsanding
I guess they said there were 2 options when doing this process...
1 - Take the water hose, turn it on and let it run as you're sanding the area with the sandpaper, turn it off when finished and buff
or
2 - Let the sandpaper soak overnight in a bucket of lukewarm water and sand any small given area with it, rinse with water, and then buff
Is this correct? Or is it a little more detailed/complicated than this? I'm really not too concerned if they don't turn out looking perfect, just a little curious
04-25-2010, 07:32 PM #12
Just dip the paper in water as you go and keep the surface wet. No hose or pre-wetting is necessary.
04-25-2010, 07:34 PM #13Senior Member
- Oct 2008
- Coral Springs, Fl
just make sure your surface and paper are wet while sanding, dipping like said above works good.
04-25-2010, 07:35 PM #14
try using tooth paste. It works pretty good. use it with a buffer or you can just use alot of elbow grease. Don't laugh it works....
04-25-2010, 07:42 PM #15Senior Member
- Nov 2009
- NOVA
Advice notated... I'll make sure to take some before and after pictures as well! Kind of can't wait to get started on it!
04-25-2010, 08:52 PM #16
Weird that the first post was about the headlights, I was thinking the same thing
04-25-2010, 08:54 PM #17Senior Member
- Oct 2008
- Coral Springs, Fl
Just noticed, is your antenna bent over a little?
04-25-2010, 11:34 PM #18Junior Member
- Jan 2010
- indiana
- ford ranger
The guys on the t.v show truck did the toothpaste thing and the results were pretty impressive.
04-26-2010, 08:22 AM #19
Looks like someone jacked your car in the wrong spot too, but you can fix that.
Take a 2x4 and bang it back in. There is a metal plate below that area that has two screws protruding. Someone jacked it up there and you can bang on that and get that panel back in.
Might not be the best way to do it, but your panels will line up again. Up to you..
04-26-2010, 09:45 AM #20
Question: Boring .020 Over
By BJDahlke in forum Internal EngineReplies: 34Last Post: 03-03-2009, 07:09 AM -
Question: TB Boring
By mark21742 in forum Internal EngineReplies: 0Last Post: 02-24-2009, 02:33 AM -
Boring
By Fearls1 in forum Firebird / WS6Replies: 13Last Post: 08-13-2008, 04:24 PM -
ls1.com getting a little boring?
By Frankthetank in forum Almost Anything GoesReplies: 78Last Post: 03-20-2008, 10:42 PM -
boring a 5.3 to 5.7?
By FORMULA7 in forum Internal EngineReplies: 14Last Post: 03-27-2007, 07:37 PM
