03-14-2007, 07:15 AM #1Member
- Feb 2007
- In front of you, where else?
- iTrader
- 1 (100%)
Black- 1993 Camaro Z28
Crane Cams LS1 In-Car Valve Spring Compressor
This trick valve spring compressor is intended for ALL LS1's for those who want to change out their springs on the car, without removing your heads. It was used only once and is toooo easy to use! Awesome tool from Crane; BEST compressor in the market right NOW!! A MUST if you upgrade your cam like I did and dont want the added effort/expense in removing your heads! Price new $119.00, asking $75.00 !!!! Still in new box with plastic wrapper,instructions and all! Crane Cams model # 99472-1V.
03-14-2007, 06:47 PM #2
let me see some pic [email protected]
03-14-2007, 07:48 PM #3Member
- Feb 2007
- iTrader
- 1 (100%)
Bought new Kodak camara and used up power on batteries. It came with no charger; have to purchase separately, just after I shelled out $399.00 for it!!!!!!!!!! SUCKS for me. Anyhow, unit is in perfect shape, not beat up, dropped, scored or anything!! It is still basically brand new. I only used it for the set of springs that were towards the back of the block that are just about impossible to get to. Jegs.com has the unit so you could see it! Go to tools on the left side, will take you to vendors; find Crane Cams and you will see it there. They are asking 115.00 I beleive! Thanks!
03-15-2007, 09:23 PM #4
http://www.jegs.com/webapp/wcs/store...55182_-1_10793
this tool?
and how does this tool work do i need an air compressor or that thing help hold up the valve can u explain how does it work plz thx and what is your location
03-16-2007, 07:28 AM #5Member
- Feb 2007
- iTrader
- 1 (100%)
Yup,thats the tool!! Depending on mileage, (10,000 miles or less) and bravery, it is possible to change springs on your LS1 without air in cylinder. However you will need a magnet to pull valves that drop slightly. If you never changed a cam in an LS1 before or have previous experience with spring removal, I recommend you use compressed air or the rope method. This Crane Compressor make the job REAL easy! It does 2 springs at the same time and centers/locates the compression around the retainer so that compression is even on both sides and does an awesome job centering around the valve; doesnt touch the valve, helpful if you are not running air in cylinders! Use magnet to retrieve tip of valve if one slides down some! I personally had no problem at 79,000 miles!! But I have experience on changing camshafts on LS1 and that is helpful because I already know what to expect! Using the rope method,(sticking/shoving rope in cylinder while changing springs) is expiditing alternative if you dont have an air compressor. Either way, this unit I found thru Crane is the BEST Ive used and seen, even better than the MORE compressor because it is made of aluminum and the 3/8 ratchet opening starts to round out quick then turns to junk!! Stick to Crane, it WORKS! Anyway, I live here in Kissimmee,FL. I will do $80.00 shipped!!
Last edited by jrgswhitels1; 03-16-2007 at 07:30 AM. Reason: Confrimation of product
03-16-2007, 08:45 PM #6
03-17-2007, 07:58 PM #7Member
- Feb 2007
- iTrader
- 1 (100%)
Best I can do is $75.00 bucks FIRM, that includes insured shipping to your front door Pal!
Question: Valve spring compressor tool
By red00bird in forum Firebird / WS6Replies: 8Last Post: 02-14-2012, 11:25 AM -
WTB LS1-LS6 Valve Spring Compressor tool
By biga0206 in forum Parts Wanted / TradeReplies: 0Last Post: 06-24-2008, 07:20 PM -
Crane Valve spring compressor in-car for LS1
By jrgswhitels1 in forum Parts For Sale / TradeReplies: 1Last Post: 10-01-2007, 05:38 PM -
piston to valve clearence with crane cams quick lift rocker arms?
By Rob00Taws6 in forum External EngineReplies: 3Last Post: 06-22-2007, 02:19 PM -
what valve spring compressor to use?
By mvvette97 in forum General HelpReplies: 3Last Post: 09-26-2006, 02:34 PM
