Thread: Valve spring compressor tool
02-13-2012, 12:53 PM #1
What tool have you guys used for DUAL valve springs I want to buy a reliable one that will do the job right
Polluter,410 gears,ls6 intake,pacesetter long tubes ,tsp true duals,slp pulley,slp lid,stock pp throttle body,strano springs n sway bars,founders performance stb,Lca's and Lca relocation brackets,adjustable phb and phb relocation bracket,umi 3point sfc's ,diamond stg2 clutch,koni 4/3s,mgw shifter
02-13-2012, 01:39 PM #2
Subscribed. I see that both Trick Flow and Comp Cams have valve spring compressor tools listed in Summit's LS/LT section now.
02-13-2012, 01:46 PM #3
I saw those but then I heard some stories that some can't get the dual spring down enough to put the locks on I was looking at the one from thunder racing that does 2 in one shot
02-13-2012, 01:54 PM #4
With the head on or off the vehicle
02-13-2012, 01:56 PM #5
Taking the heads off
02-13-2012, 02:05 PM #6
Here is what I use. Makes things super easy.
You place the silver part by itself on top of you valve spring and give it a good whack with a hammer. Place rags under your head when doing it. It pushed the spring against the head while the valve does not move the keepers loosen and get pulled into the tools magnet.
02-13-2012, 02:19 PM #7
I sent a reply with pics. Said waiting for mod to approve
02-14-2012, 11:07 AM #8
Where did you buy that tool
02-14-2012, 11:25 AM #9
Bought it of Matco truck
valve spring tool?
By breathnitrous in forum Internal EngineReplies: 2Last Post: 04-13-2010, 05:57 PM -
WTB LS1-LS6 Valve Spring Compressor tool
By biga0206 in forum Parts Wanted / TradeReplies: 0Last Post: 06-24-2008, 07:20 PM -
what valve spring compressor to use?
By mvvette97 in forum General HelpReplies: 3Last Post: 09-26-2006, 02:34 PM -
Valve Spring Compressor Tool $ 30 Shipped
By 2001 SOM WS6 1969 GTO in forum Parts For Sale / TradeReplies: 4Last Post: 09-20-2006, 02:23 PM
