Results 1 to 2 of 2
03-12-2007, 02:52 PM #1Junior Member
- Feb 2007
- Clinton, MI
Red- 1996 TransAM Supercharged
1996 T/A 6 speed/rear end questions,
Anyone have trouble with a 6 speed hard to get into and stay in reverse? It seems like it barely goes into reverse, not a solid feel at all, and pops out of reverse sometimes. All other gears are fine. I got a copy of the 96 GM trans diagnosis manual and it says the reverse lockout could be bad. Anyone see this go bad on theirs? Also, what type of performance gain do you guys think I would see with my 350 horse-supercharged car going from a 3:42 to a 4:10? (I'm assuming the car has a 3:42 in it now). Also, how high does a 4:10 rev to at 70 MPH or so? Thanks for the help.
Dave
03-14-2007, 04:09 AM #2Member
- metro Detroit area
A bad reverse solenoid will not cause your problem. Solenoids nearly never go bad. A malfunctioning solenoid is more likely an electrical/ control issue. If it were malfunctioning it would result in very high efforts to get into the reverse gate but it would not cause a jump out. A jump out is more likely due to worn reverse driven gear clutch teeth, worn synchronizer sleeve teeth,bent shift fork, worn shift fork pads or all of these things.
94 6 speed trans questions
By CDBROWN in forum Classic MuscleReplies: 1Last Post: 08-10-2008, 08:40 AM -
6 Speed tranny of a 1996 Trans am LT1
By Cargod9373 in forum Parts For Sale / TradeReplies: 0Last Post: 10-10-2007, 09:18 AM -
6 speed questions?
By Airguy in forum Manual TransmissionReplies: 6Last Post: 05-20-2007, 08:39 PM -
6-Speed 350 in 3rd gen questions....
By Silver Streak in forum General HelpReplies: 0Last Post: 03-09-2007, 05:11 PM
