Results 1 to 2 of 2
10-08-2005, 02:11 PM #1Junior Member
- Oct 2005
black- 2001 TA
is the divider hole in lower airbox used for anything?
If you look inside the lower airbox you can see the plastic piece in the middle that seperates the left and right side. It looks like its there for structure, but it certainly does nothing for flow since it has small walls and a big hole that leads right to the radiator. This piece is right in the middle and touches the stock airfilter in the center if you look inside and slightly up. I can't imagine it is robbing lots of power, but its not helping any either. I'd like to just seal it up with some bondo, but just want to make sure its not there for a purpose. I am guessing its just there to rob some airflow, since GM put in all those baffles and stuff. Anyone have any guess, if this is bad to seal and smooth out.
--2001 TA WS6 -- flowtech headers, cutout, 4.10 gears
10-09-2005, 09:54 AM #2
You can learn more about the air filter tray and the free ram air mod here: "installuniversity.com/install_university/index.htm" under Main go to Install Documents and then under Air Induction click on Free Ram Air...
ws6 lower airbox
By 5second in forum Parts Wanted / TradeReplies: 0Last Post: 11-03-2008, 10:15 AM -
Do I need lower airbox?
By patriot1136 in forum General HelpReplies: 1Last Post: 11-02-2008, 11:20 PM -
Wanted: Lower Airbox For 98-02 WS6
By ExStanger in forum Parts Wanted / TradeReplies: 0Last Post: 03-03-2008, 12:31 PM -
Should i get the WS6 lower airbox?
By GottaHaveLS1 in forum General HelpReplies: 13Last Post: 12-26-2006, 03:45 PM -
Do I need the whole lower airbox assembly??
By Uno99 in forum General HelpReplies: 5Last Post: 10-30-2005, 07:11 AM
