Results 1 to 3 of 3
    Member gd1996's Avatar
    Latrobe, PA
    What ram air box for a 94 converted to 98+
    I converted my 94 ta to a 98+ and got a functional ws9 hood. So what air box could I used to make it functional?
    Latrobe, PA
    Im screwed?
    Hershey PA
    1994 Trans Am
    I would have to see pictures,but I think that you should be able to get the
    ls1 upper rad support(The black plastic part that the air lid snaps onto) and just use a hi flow lid for those cars. Just keep in mind that the ls1 cars have a different radiator /headlight support bar (The metal piece that your headlight assemblys bolt to) than the lt1 cars. The ls1 piece dips down in the center for increased clearence for the air box assembly. The lt1 cars do not. Also unless you have the Ram Air hood,you will have to use the standard plastic rad support from the NORMAL Trans am or Camaro, because the one from the ws6 car is higher and will probably hit your hood,if you didn't change the metal radiator support as mentioned above. Good luck Joe
  1. Anyone converted 06 Corvette transmission to 02 Trans Am?
    By Anderson0741 in forum Manual Transmission
    Last Post: 10-26-2011, 06:16 PM
  2. Question: gto converted
    By burnsxxxls1 in forum GTO
    Last Post: 06-12-2010, 10:37 PM
  3. Converted
    By MatNova in forum New Member Introductions
    Last Post: 06-24-2008, 01:39 PM
  4. converted another one
    By hutch1999 in forum Firebird / WS6
    Last Post: 06-15-2008, 09:59 AM
